I can’t use Airplay to play sound to Kodi (CoreElec 9.0.3 on ODROID C2) with my Mac (macOS 14.5) or iPhone (iOS 12.3).
The Mac or phone will show Kodi and let me select it as output device but when I try to play any sound I only get an error message I don’t see any message in the kodi.log with debug switched on.
Interesting. I had Airplay working sometimes in the past on different versions of Kodi on different hardware so I was not able to say when it stopped working and what it correlated with…
After trying also with 9.0.2 which didn’t work in the beginning but started working after I switched Airplay off an on a couple of times it also started working on 9.0.3
The best way seems to be to switch off Aiplay in Kodi, wait until it vanishes in the Airplay device list and then switch it back on. Now it works
It seem not work anymore for above iOS12 device with airplay,while airtunes dose work all the time.
but if your app support DLNA ,like NPlayer ,it can post your video to screen too.
Hope CoreElec can support iOS new version soon.
Well, with all respect, it’s not an Apple issue, and it’s not a Kodi issue. It’s CoreElec one, because it works in other Kodi installation, and stopped worrking in CoreElec
Obviously, you are not obliged to fix it, as you are not obliged to work on CoreElec at all, but pls. don’t shift the focus
If you don’t know how to fix it, or don’t want to fix it, just say so, without pointing fingers to Apple
hello please coud I cast my screen with coreelec (an application like miracast)
PS: I used the yatse application but i could just cast the yotube and use it as remote control
