CE-22 NO: Looking for users with no working WiFi or BT
H96 Max X4 CE-no Wifi not working BT working, everything works with CE-ng and CE-ne.
here´s the logs
dmesg | paste - https://paste.coreelec.org/HopperHabits
udevadm info /sys/bus/sdio/devices/* | paste - https://paste.coreelec.org/HorsemanWalls
lsusb | paste - https://paste.coreelec.org/GownsMutual
udevadm info /sys/bus/pci/devices/* | paste & lspci | paste - https://paste.coreelec.org/EmptyPaste
X88 Pro X5M runing on CE-NO 20250814-Generic with no wifi and no bluetooth detected.
dmesg: https://paste.coreelec.org/AllowsConey
udevadm info: https://paste.coreelec.org/GustavArranged
lspci is empty and lsusb has no mention related to wifi.
I don’t think this chip can be supported:
SDIO_ID=0000:0000
No ID, no driver, nothing…
Something I can do android side to help? Seems to be a poor wifi 6 chipset (connected to 802.11ax interface on my ISP box)
Maybe take Box apart,grab some pics of board
Top and underside upclose wifi chipset/ethernet transceiver
Will help identify chipset
Chip already identified: EA6521QF.
Seems the driver is seekwave ea6x21qx.
Test image for wifi on X88 Pro X5M.
https://test.coreelec.org/vpeter/CoreELEC-Amlogic-no.aarch64-22.0-Piers_devel_vpeter-X88-Pro-X5M-wifi-01.tar
If not working please enable terminal sharing: coreelec:term_share [CoreELEC Wiki]
not working.
terminal is shared please confirm if you can connect.
tmate not visible
I just set my username as connection name. Should I send an invitation to the CoreELEC developers?
Anyway here’s the dmesg log including the error related to the new driver
https://paste.coreelec.org/MundaneNinety
Problem probably continue here
[    4.647695] [SKWBOOT]:firmware: SWT6621_DRAM_SDIO.bin SWT6621_IRAM_SDIO.bin
[    4.648137] (NULL device *): Direct firmware load for SWT6621_DRAM_SDIO.bin failed with error -2
but I’m not wiling to continue doing support with test images.
ok thanks, will plug my old wifi key on that until a working driver is found.
It is found. But without device or at least with remote access to test it nothing will change regarding this driver.
OK thanks for your work. I will retest the image and try to configure you an access starting monday (just updated to yesterday image sooner).
GPT seems to indicate by error -2 that a file is missing
The ideal time for me to work on is weekend. I do have real job to work on.
found those 2 files on android:
./vendor/lib/firmware/SWT6621_DRAM_SDIO.bin
./vendor/lib/firmware/SWT6621_IRAM_SDIO.bin
is there something to do with?
It’s lunch time here.
I will reflash your image tomorrow for further the investigation.
I copied the two files into /storage/.config/firmware, and they are now loading successfully. Unfortunately, there’s still a third file missing, which I couldn’t find on Android. Here’s the log:
[    4.680774] [SKWBOOT]:firmware: SWT6621_DRAM_SDIO.bin SWT6621_IRAM_SDIO.bin
[    4.701432] [SKWBOOT]:boot data dram_img_data 00000000eb57407d
[    4.741401] [SKWBOOT]:boot data iram_img_data 000000001585e546
[    4.758153] (NULL device *): Direct firmware load for SEEKWAVE_NV_SWT6621S.bin failed with error -2
[    4.758177] [SKWBOOT_ERR]: NV image request_firmware SEEKWAVE_NV_SWT6621S.bin fail
Terminal sharing is activated with my username as connection name.
If you can’t connect, I will provide you a direct ssh access through private message.
Thanks in advance for your investigation.
I did reboot the device with the binary placed but it does not come back online with tmate. Please check it!
