In case you updated to Amlogic-no (New Order) and you got no Wifi/BT working please make a report:
Tried lasted available Nightly build?
Device used?
Wifi/BT is working by using Amlogic-ng and or Amlogic-ne ? If this is the case please provide dmesg | paste with latest corresponding nightly installed!
SDIO Wifi SoC
4.1 udevadm info /sys/bus/sdio/devices/* | paste
USB Wifi SoC
5.1 lsusb | paste
PCI Wifi SoC
6.1 udevadm info /sys/bus/pci/devices/* | paste
6.2 lspci | paste
dmesg | paste after reboot
Please follow the CoreELEC Wiki for more details how to create useful logs. In case of a request from Team CoreELEC enable a Tmate session to share the device for remote debugging.
Secam7
20 December 2023 18:08
4
I’m testing the new Amlogic-no on my MECOOL M8S and everything works except wifi.
I am using the g12a_s905x2_2g.dtb file. This box uses wifi card rtl8189fs on sdio .
Can I ask you to modify the dts file as follows?
The key lines are:
+/* SDIO */
+&sd_emmc_a {
+ status = "okay";
+ pinctrl-0 = <&sdio_pins>;
+ pinctrl-1 = <&sdio_clk_gate_pins>;
+ pinctrl-names = "default", "clk-gate";
+ #address-cells = <1>;
+ #size-cells = <0>;
+ bus-width = <4>;
+ cap-sd-highspeed;
+ max-frequency = <40000000>;
+ non-removable;
+ disable-wp;
+ /* WiFi firmware requires power to be kept while in suspend */
+ keep-power-in-suspend;
+ mmc-pwrseq = <&sdio_pwrseq>;
+ vmmc-supply = <&vddao_3v3>;
+ vqmmc-supply = <&vddao_1v8>;
+ rtl8189fs: wifi@1 {
+ reg = <1>;
I’m adding more information:
dmesg from Amlogic-ng: https://paste.coreelec.org/LeERD5
and SDIO WiFi SoC: https://paste.coreelec.org/ZHgWYd
I am sorry but this want work. Like sdio_clk_gate_pins is not defined at all so how it should work?
Your problem only is that Amlogic-no does not (yet) include a driver for 024C:F179.
The driver RTL8189FS-aml must be fixed to compile with 5.15 kernel.
Secam7
20 December 2023 19:16
6
Thanks, I’ll wait then.
This example was with LibreElec and kernel 6.x.
If necessary, I will paste the dts file from kernel 4.9.
DigiTo
21 December 2023 15:13
7
WiFi and BT are not working in NO build (latest nightly), but work in NG builds.
Device: X96 Max Plus2 (S905x3, 4GB RAM, 1Gbit Ethernet)
DTB: sm1_s905x3_4g_1gbit
DMESG (NG): https://paste.coreelec.org/d3PmoW
DMESG (NO): https://paste.coreelec.org/pbs1X6
SDIO (NG): https://paste.coreelec.org/yD0D6w
Is this log from NG or NO?
Because the NO dmesg log says:
[ 7.457572] [extern_wifi_set_enable] WIFI Enable! 482
[ 7.784384] meson-gx-mmc ffe03000.sdio: card claims to support voltages below defined range
[ 7.824972] mmc2: tuning failed, reduce freq and retuning
[ 7.825402] mmc2: tuning failed, reduce freq and retuning
[ 7.825953] mmc2: tuning failed, reduce freq and retuning
[ 7.826516] mmc2: tuning failed, reduce freq and retuning
[ 7.827163] mmc2: tuning failed, reduce freq and retuning
[ 7.827858] mmc2: final result of tuning failed
[ 7.827868] mmc2: tuning execution failed: -1
[ 7.827879] mmc2: error -1 whilst initialising SDIO card
DigiTo
21 December 2023 15:31
9
It’s from NG because on NO I’m getting
Unknown device "/sys/bus/sdio/devices/*": No such device
I also can’t get Wifi working right now on SM1. But maybe the newer kernel version will fix this issue.
@DigiTo please try again after update with new nightly:
I uploaded a new nightly of Amlogic-no.
Some errors reported here are fixed:
fix vim1s fb mem
fixed SDIO on sm1
DigiTo
22 December 2023 09:58
12
Now it works correctly, thanks.
icy
22 December 2023 10:01
13
Moving it here since it’s amlogic-no
Got an issue with an 8822bu WiFi USB adapter.
lsusb: paste.coreelec.org/oPBNX7
dmesg: paste.coreelec.org/lrHkGv
Kernel panic always occurs when trying to transfer files to the device. Related to VHT I’m guessing?
Rate marked as a VHT rate but data is invalid: MCS: 0, NSS: 0
It’s an Odroid N2 running amlogic-no.
it only looks like a warning:
[ 279.858272] Rate marked as a VHT rate but data is invalid: MCS: 0, NSS: 0
[ 279.858297] WARNING: CPU: 3 PID: 31 at net/mac80211/rx.c:4933 ieee80211_rx_list+0x6e8/0x9b0
And wifi looks like working:
wlan0: authenticated
Please make a issue at the driver author:
Secam7
22 December 2023 10:33
15
Maybe the drivers from this source will be suitable for my WiFi card?
yes, this looks good:
#ifdef CONFIG_RTL8192E
{ SDIO_DEVICE(0x024c, 0x818B),.driver_data = RTL8192E},
#endif //CONFIG_RTL8192E
#ifdef CONFIG_RTL8703B
{ SDIO_DEVICE(0x024c, 0xB703), .driver_data = RTL8703B},
#endif
#ifdef CONFIG_RTL8188F
{SDIO_DEVICE(0x024c, 0xF179), .driver_data = RTL8188F},
#endif
#if defined(RTW_ENABLE_WIFI_CONTROL_FUNC) /* temporarily add this to accept all sdio wlan id */
{ SDIO_DEVICE_CLASS(SDIO_CLASS_WLAN) },
#endif
{ /* end: all zeroes */ },
MODULE_DEVICE_TABLE(sdio, sdio_ids);
The driver used for Amlogic-ng is not compatible and it’s a lot of work to lift it up to 5.15.
So such solution looks better. I will try when I get some time.
Portisch:
F179
@Secam7 please try new nightly if your USB RTL8189FS does work now, thx.
alias sdio:c*v024CdF179* 8189fs
Secam7
23 December 2023 16:39
18
Unfortunately, the card did not start: dmesg https://paste.coreelec.org/nopeqv
Problem initializing sdio port?
Looks like, yes. The new Kernel version have some fixes about SDIO & g12a so maybe it start working with this version.
Secam7
23 December 2023 18:19
20
Using dtc, I reduced the max-frequency to this: max-frequency = <0xa21fe80>;
After such a change, loading the 8198fs module causes the box to reboot.
Too bad it doesn’t work, but thank you very much for your help.
