Hi…my CE 19.4-Matrix_rc3 instalation crashing during idle at gui. When streaming, everything is OK. Can someone look at my crash log and try to debug, where can be problem?
https://paste.kodi.tv/nofasoviya.kodi
First update to 19.5-Matrix_rc2 and see if still the same or better.
And I see you have some banned addons installed which usually cancel support here.
Thanks for reply. At 19.5 rc2 same problem. The log was taken during the test downgrade. About banned add-on - I will remove it and send a new crash log.
