pleas,
I mount CE internal eMMc to box S905X3,
how to make Hard Reset when the possibility “Kodi - System - Coreelec - System - Hard Reset” dont work
after a reboot, the system remains unchanged
You could hard reset by reinstalling with an sdcard.
but when I use the command again “CoreELEC:~ # ceemmc -x”
nothing will change
is a command for SSH?
I had similar issue with Hard Reset not working after installing CE on eMMC.
You can try yesterday nightly build that have the fix for the Hard Reset issue on eMMC.
https://relkai.coreelec.org/
