Thanks for that In fact I just checked with a file sample from kodi and my S905X3 box do DV here my sample IMG-20241105-181146-8846 hosted at ImgBB — ImgBB but thanks for the tweak passthrough. So I answer myself My Android Tv system Sony AND my box do DV its cool… For people who want to try they will found sample files here https://kodi.wiki/view/Samples#4K_(UltraHD)_Formats
The sample you chose is DV/HDR10+. Your box doesn’t support DV, so it’s falling back to HDR10+.
Well YadaYada My TV is NOT HDR10+ only HDR10 and the sample is HDR10+ and DV. If my box do not play DV I just have blank display (or black) this is whats happens to people who do not have 10+ or DV with their box If I trust their comments
HDR10+ falls back to HDR10 when HDR10+ isn’t supported.
DV decoding requires DV licensing. Your s905x3 is not DV licensed, it will not decode DV in CE or Android.
Wrong forum!
Hi folks,
I own a DuneHD Homatics BoxR 4K+ (black box) and run it fine on CE-NE 21.1.1 through a Denon AVR to an OLED TV. Everything works fine and all formats are supported (HLG, HDR10+, DolbyVision).
For a test run, on a new USB stick, I tried CE-NG to see if FEL is correctly supported. I used CoreELEC-Amlogic-ng.arm-21.1.1-Omega_nightly_20241106-Generic.img with both sc2_s905x4_sei_smb_280.dtb and sc2_s905x4_4g_1gbit.dtb. Ethernet works fine and WiFi/BT seem to work properly as I can see SSIDs and BT devices. However, I can not get DV to even show up in Kodi settings, only the usual HDR to SDR and SDR to HDR options.
dmesg shows that dovi.ko isn’t loading, of course, I used the s905x4 version
[ 0.834850@1]- g12 dovi disable in uboot
[ 15.187555@1]- dovi: disagrees about version of symbol module_layout
[ 15.187566@1]- dovi: module license 'AML' taints kernel.
[ 15.187568@1]- Disabling lock debugging due to kernel taint
[ 15.189509@1]- dovi: disagrees about version of symbol register_dv_functions
[ 15.190461@1]- *** amlogic_dolby_vision_init dv: null ***
[ 15.190465@1]- *** register_dv_stb_functions.***
[ 15.190550@1]- hdr10_policy 115, ko_info THE GOLDEN FLUENT TECHNOLOGY AND SCIENCE HK LIMITED [stb:2.4:e]-[v1.0]-[ Mon Oct 5 20:07:12 CST 2020]-[ brian.zhu]-[* stb_2.4]-[18510d0c6c2246e2fe28c45ae9f71b68e2bd23fa]-[Date: Sat Oct 3 21:25:19 2020 -0700]-[0]
[ 15.190560@1] dv capability 7
When login with SSH, the greetings message is
CoreELEC (official): 21.1.1-Omega_nightly_20241106 (Amlogic-ng.arm)
Machine model: Dune/Homatics R 4K Plus
CoreELEC dt-id: sc2_s905x4_sei_smb_280_id5
Amlogic dt-id: sc2_s905x4_ah212-id5
Linux version: 4.9.269 (docker@a0dd02997a79) #1 Wed Nov 6 07:14:52 IST 2024
Kodi compiled: 2024-11-06 05:58:39 +0000
System info → Hardware says : CPU: Amlogic S905X4 rev d
Before bothering people here I have an important question : Before using CE-NG, do I need to reboot to Android and let it update everything or is CE really totally independent of AndroidTV?
I ask because I see here a lot of messages about people updating AndroidTV to the latest release.
My DuneHD device was booted out of the box around April 2024, Android updated itself, rebooted and then bootstrapped the normal installation process. When it reached the point where it needed to login with a Google account, I switched off the device and never booted AndroidTV again (except by error by forgetting to plug the USB stick
). I only used CE-NE ever since and I am happy with it.
But now, I can’t get DV to work out of the box on a fresh install of CE-NG and I wonder if that’s the reason.
Thank you for any information.
The dmesg output is normal, the next two lines after what you posted are likely
efuse_mode=0 reg_value = 0x18
dv capability 7
If that is what appears, the DV module loaded successfully.
The Kodi DV related settings depend on the DV module being loaded, and the connected television reporting DV capabilities.
CE is almost entirely independent of Android. In your case I don’t think Android is the problem.
I edited the original message to report dv capability 7 and you’re right about the efuse_mode line.
Ok so I can’t see where the problem is
I shutdown CE-NG and plugged back my original USB stick with CE-NE CoreELEC (official): 21.1.1-Omega (Amlogic-ne.aarch64) and everything is back to normal again. Everything is working fine as expected and DV is back too on exactly the same conditions.
I’m a bit puzzled here to say the least ![]()
And thank you for the clarification on the relationship between ATV/CE because, for a new comer to the CE world, it wasn’t very clear, at least to me.
For further info, here’s the dmesg output on CE-NE CoreELEC (official): 21.1.1-Omega (Amlogic-ne.aarch64)
[ 16.582115@1] *** amlogic_dolby_vision_init dv: sc2 ***
[ 16.582131@1] *** register_dv_stb_functions.***
[ 16.582151@1] hdr10_policy 115, ko_info THE GOLDEN FLUENT TECHNOLOGY AND SCIENCE HK LIMITED chip_name = sc2 [stb:2.4:e]-[v1.0]-[ Mon 13 Feb 2023 02:08:07 PM CST]-[ jialong.jiang]-[* stb_2.4]-1fecf8d96bae61ce5e1043c53050083cd34c4559]-[Date: Mon Nov 14 10:54:07 2022 +0000]-[0]
[ 16.582158@1] efuse_mode=0 reg_value = 0x18
[ 16.582161@1] dv capability 7
And we can see sc2 instead of null after amlogic_dolby_vision_init
I see used 2 different dovi.ko modules (different versions).
On my day-to-day CE-NE, I haven’t touched dovi.ko by myself so it’s the default shipped file, probably /android/odm/lib/modules/dovi.ko as this is the only one I could find on the whole filesystem.
/android/odm/lib/modules/dovi.ko - 1624928 bytes
SHA256 : 5cabac0b63972169266625fef73f040a673ad8cf887286f576788fd6a0c2d7b1
On the CE-NG test run, it’s the S905X4 file from Mega.nz listed on the post here : CE-NG Dolby Vision (+FEL) for DV-licensed SOCs (s905x2, s922x/z, s905x4)
dovi.ko - 1290671 bytes
SHA256 : 50fbf5f721ddb8d567ed3a3759d0a51ec7d02abfd5e9ec24c53db40e1d78d4ef
so yes, they are very different but I guess this is to be expected right?
null is normal output for that 4.9 module on the s905x4. Yeah, the shipped module included with the box is compiled for kernel 5.4, and the NG version is for 4.9, they are different and the dmesg output won’t be exactly the same.
It looks like the DV module is loading fine. Try reflashing that USB stick with CE-NG to be sure there wasn’t some problem during the initial CE setup that is causing problems.
Already did that
I posted my initial message after 2 flash attempts.
Flashed the IMG file and did not include dovi.ko at all, did the initial kodi wizard setup and shutdown. I placed dovi.ko on storage and booted up, no joy.
Scratched all and did flash the IMG again, this time including dovi.ko on the flash partition.
/usr/lib/coreelec/dovi-loaderscript confirms it tries to load it from there and it did. Anyway, I moved the dovi.ko file to/storagejust in case but again, to no avail.
This is a big (and unpleasant) mystery ![]()
What’s the output of
cat /sys/class/amhdmitx/amhdmitx0/edid
Yes, of course. Stupid me.
Connection chain, in case it makes any difference:
DuneHD BoxR → Denon AVC-X4800H → Panasonic TX65LZ1500E
CE-NG - Troublesome
Rx Manufacturer Name: DON
Rx Product Code: 0076
Rx Serial Number: 01010101
Rx Product Name: DENON-AVR
Manufacture Week: 0
Manufacture Year: 2022
Physcial size(mm): 1280 x 720
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0xfd
Source Physical Address[a.b.c.d]: 1.2.0.0
native Mode f0, VIC (native 97):
ColorDeepSupport b8
97 96 16 31 5 20 32 33 34 4 19 3 18 93 94 95 63 64 1 95 94 93 353 352
Audio {format, channel, freq, cce}
{1, 7, 7f, 7}
{7, 5, 1e, c0}
{2, 5, 7, 50}
{11, 7, 7e, 3}
{10, 7, 6, 3}
{12, 7, 7e, 3}
{9, 5, 2, 0}
{15, 3, 4, 5b}
{11, 7, 7e, 1}
Speaker Allocation: 5f
Vendor: 0xc03 ( HDMI device)
MaxTMDSClock1 300 MHz
Vendor2: 0xc45dd8
MaxTMDSClock2 600 MHz
ALLM: 1
vLatency: Invalid/Unknown
aLatency: Invalid/Unknown
i_vLatency: Invalid/Unknown
i_aLatency: Invalid/Unknown
ColorMetry: 0xdf
SCDC: 1
RR_Cap: 0
LTE_340M_Scramble: 0
HDR/15 DeepColor
checkvalue: 0xfd170000
cat /sys/class/amhdmitx/amhdmitx0/dv_cap
The Rx don't support DolbyVision
edid-decode /sys/devices/virtual/amhdmitx/amhdmitx0/rawedid
edid-decode (hex):
00 ff ff ff ff ff ff 00 11 ee 76 00 01 01 01 01
00 20 01 03 80 80 48 78 0a da ff a3 58 4a a2 29
17 49 4b 20 00 00 31 40 01 01 01 01 01 01 01 01
01 01 01 01 01 01 08 e8 00 30 f2 70 5a 80 b0 58
8a 00 ba 88 21 00 00 1e 02 3a 80 18 71 38 2d 40
58 2c 45 00 ba 88 21 00 00 1e 00 00 00 fc 00 44
45 4e 4f 4e 2d 41 56 52 0a 20 20 20 00 00 00 fd
00 17 78 0f ff 77 00 0a 20 20 20 20 20 20 01 fd
02 03 76 f0 53 61 60 10 1f 05 14 20 21 22 04 13
03 12 5d 5e 5f 3f 40 01 3b 0f 7f 07 3d 1e c0 15
07 50 5f 7e 03 57 06 03 67 7e 03 4d 02 00 7b 04
5b 5f 7e 01 83 5f 00 00 6d 03 0c 00 12 00 b8 3c
2f 00 60 01 02 03 68 d8 5d c4 01 78 80 0b 02 e2
0f 03 e3 06 0f 01 eb 01 46 d0 00 49 03 7a 88 5c
6d 95 e5 01 8b 84 90 01 e3 05 df 01 e2 00 cb e6
11 46 d0 00 70 00 00 00 00 00 00 00 00 00 00 17
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: DON
Model: 118
Serial Number: 16843009
Made in: 2022
Basic Display Parameters & Features:
Digital display
Maximum image size: 128 cm x 72 cm
Gamma: 2.20
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6396, 0.3447
Green: 0.2910, 0.6347
Blue : 0.1630, 0.0927
White: 0.2880, 0.2958
Established Timings I & II:
DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
Standard Timings:
Detailed Timing Descriptors:
DTD 1: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz (698 mm x 392 mm)
Hfront 176 Hsync 88 Hback 296 Hpol P
Vfront 8 Vsync 10 Vback 72 Vpol P
DTD 2: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz (698 mm x 392 mm)
Hfront 88 Hsync 44 Hback 148 Hpol P
Vfront 4 Vsync 5 Vback 36 Vpol P
Display Product Name: 'DENON-AVR'
Display Range Limits:
Monitor ranges (GTF): 23-120 Hz V, 15-255 kHz H, max dotclock 1190 MHz
Extension blocks: 1
Checksum: 0xfd
Block 1, CTA-861 Extension Block:
Revision: 3
Underscans IT Video Formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 0
Video Data Block:
VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz
VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz
VIC 16: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz
VIC 31: 1920x1080 50.000000 Hz 16:9 56.250 kHz 148.500000 MHz
VIC 5: 1920x1080i 60.000000 Hz 16:9 33.750 kHz 74.250000 MHz
VIC 20: 1920x1080i 50.000000 Hz 16:9 28.125 kHz 74.250000 MHz
VIC 32: 1920x1080 24.000000 Hz 16:9 27.000 kHz 74.250000 MHz
VIC 33: 1920x1080 25.000000 Hz 16:9 28.125 kHz 74.250000 MHz
VIC 34: 1920x1080 30.000000 Hz 16:9 33.750 kHz 74.250000 MHz
VIC 4: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
VIC 19: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz
VIC 3: 720x480 59.940060 Hz 16:9 31.469 kHz 27.000000 MHz
VIC 18: 720x576 50.000000 Hz 16:9 31.250 kHz 27.000000 MHz
VIC 93: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz
VIC 94: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz
VIC 95: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz
VIC 63: 1920x1080 120.000000 Hz 16:9 135.000 kHz 297.000000 MHz
VIC 64: 1920x1080 100.000000 Hz 16:9 112.500 kHz 297.000000 MHz
VIC 1: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
Audio Data Block:
Linear PCM:
Max channels: 8
Supported sample rates (kHz): 192 176.4 96 88.2 48 44.1 32
Supported sample sizes (bits): 24 20 16
DTS:
Max channels: 6
Supported sample rates (kHz): 96 88.2 48 44.1
Maximum bit rate: 1536 kb/s
AC-3:
Max channels: 6
Supported sample rates (kHz): 48 44.1 32
Maximum bit rate: 640 kb/s
DTS-HD:
Max channels: 8
Supports DTS:X
Audio Format Code dependent value: 0x03
Enhanced AC-3 (DD+):
Max channels: 8
Supports Joint Object Coding
Supports Joint Object Coding with ACMOD28
MAT (MLP):
Max channels: 8
Supports Dolby TrueHD, object audio PCM and channel-based PCM
Hash calculation not required for object audio PCM or channel-based PCM
One Bit Audio:
Max channels: 6
Supported sample rates (kHz): 44.1
Audio Format Code dependent value: 0x00
MPEG-H 3D Audio:
MPEG-H 3D Audio Level: Level 3
Supports MPEG-H 3D Audio Low Complexity Profile
DTS-HD:
Max channels: 8
Audio Format Code dependent value: 0x01
Speaker Allocation Data Block:
FL/FR - Front Left/Right
LFE1 - Low Frequency Effects 1
FC - Front Center
BL/BR - Back Left/Right
BC - Back Center
RLC/RRC - Rear Left/Right of Center (Deprecated)
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 1.2.0.0
Supports_AI
DC_36bit
DC_30bit
DC_Y444
Maximum TMDS clock: 300 MHz
Supported Content Types:
Graphics
Cinema
Game
Extended HDMI video details:
HDMI VICs:
HDMI VIC 1: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz
HDMI VIC 2: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz
HDMI VIC 3: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz
Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8:
Version: 1
Maximum TMDS Character Rate: 600 MHz
SCDC Present
Supports UHD VIC
Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding
Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding
Supports Auto Low-Latency Mode
YCbCr 4:2:0 Capability Map Data Block:
HDR Static Metadata Data Block:
Electro optical transfer functions:
Traditional gamma - SDR luminance range
Traditional gamma - HDR luminance range
SMPTE ST2084
Hybrid Log-Gamma
Supported static metadata descriptors:
Static metadata type 1
Vendor-Specific Video Data Block (Dolby), OUI 00-D0-46:
Version: 2 (12 bytes)
Supports YUV422 12 bit
DM Version: 4.x
Backlt Min Luma: 100 cd/m^2
Interface: Standard + Low-Latency
Supports 10b 12b 444: Not supported
Target Min PQ v2: 0 (0.00000000 cd/m^2)
Target Max PQ v2: 3030 (934 cd/m^2)
Unique Rx, Ry: 0.67578125, 0.32031250
Unique Gx, Gy: 0.26562500, 0.67968750
Unique Bx, By: 0.14453125, 0.05078125
Vendor-Specific Video Data Block (HDR10+), OUI 90-84-8B:
Application Version: 1
Colorimetry Data Block:
xvYCC601
xvYCC709
sYCC601
opYCC601
opRGB
BT2020YCC
BT2020RGB
Reserved MD0
Video Capability Data Block:
YCbCr quantization: Selectable (via AVI YQ)
RGB quantization: Selectable (via AVI Q)
PT scan behavior: No Data
IT scan behavior: Always Underscanned
CE scan behavior: Supports both over- and underscan
Vendor-Specific Audio Data Block (Dolby), OUI 00-D0-46:
Version: 1 (7 bytes)
Height speaker zone present
Surround speaker zone present
Center speaker zone present
Checksum: 0x17 Unused space in Extension Block: 9 bytes
CE-NE - Everything working
Manufacture Week: 0
EDID Version: 1.3
blk0 chksum: 0xfd
ColorDeepSupport b8
{1, 7, 7f, 7}
{7, 5, 1e, c0}
{2, 5, 7, 50}
{11, 7, 7e, 3}
{10, 7, 6, 3}
{12, 7, 7e, 3}
{9, 5, 2, 0}
{15, 3, 4, 5b}
{11, 7, 7e, 1}
Vendor2: 0xc45dd8
ALLM: 1
ColorMetry: 0xdf
SCDC: 1
RR_Cap: 0
DolbyVision2 HDR/15 DeepColor
DolbyVision RX support list:
VSVDB Version: V2
2160p60hz: 1
Support mode:
DV_RGB_444_8BIT
DV_YCbCr_422_12BIT
LL_YCbCr_422_12BIT
IEEEOUI: 0x00d046
EMP: 0
VSVDB: eb0146d00049037a885c6d95
edid-decode (hex):
Block 0, Base EDID:
Manufacturer: DON
Model: 118
Made in: 2022
Digital display
Gamma: 2.20
RGB color display
Standard Timings:
Extension blocks: 1
Checksum: 0xfd
Revision: 3
Basic audio support
Video Data Block:
Audio Data Block:
Linear PCM:
Max channels: 8
DTS:
Max channels: 6
AC-3:
Max channels: 6
DTS-HD:
Max channels: 8
Supports DTS:X
Max channels: 8
MAT (MLP):
Max channels: 8
One Bit Audio:
Max channels: 6
MPEG-H 3D Audio:
DTS-HD:
Max channels: 8
FC - Front Center
BC - Back Center
Supports_AI
DC_36bit
DC_30bit
DC_Y444
Graphics
Cinema
Game
HDMI VICs:
Version: 1
SCDC Present
Supports UHD VIC
SMPTE ST2084
Hybrid Log-Gamma
DM Version: 4.x
xvYCC601
xvYCC709
sYCC601
opYCC601
opRGB
BT2020YCC
BT2020RGB
Reserved MD0
The raw EDID is the same between CE-NE and CE-NG, but it looks like DV capabilities aren’t being detected in NG.
CE-NG
**HDR/15 DeepColor**
CE-NE
**DolbyVision2 HDR/15 DeepColor**
So the Kodi DV menu remains hidden. Does DolbyVision appear under ‘/sys/class/amhdmitx/amhdmitx0/edid’ when you connect the box directly to the television under CE-NG?
Sorry for the delay, life happens as usual ![]()
Connecting CE-NG directly to the TV makes no difference, still no DV detected. At least, the Denon AVR can’t be blamed ![]()
In case you’re wondering, all the HDMI cables are
Ultra High Speed HDMI Certified 3-Pack 48Gbps 8K HDMI Cable 6.6 ft / 2m
and the builtin HDMI tester in the Denon AVR confirmed the 8K certification.
Rx Manufacturer Name: MEI
Rx Product Code: a296
Rx Serial Number: 01010102
Rx Product Name: Panasonic-TV
Manufacture Week: 0
EDID Version: 1.3
blk0 chksum: 0xd3
Source Physical Address[a.b.c.d]: 1.0.0.0
ColorDeepSupport 38
97 96 16 31 5 20 32 33 34 4 19 3 18 118 117 93 94 95 63 64 1 95 94 93 353 352
{1, 5, 7, 1}
{2, 5, 7, 50}
{10, 7, 7, 1}
{12, 7, 4, 3}
Speaker Allocation: f
Vendor2: 0xc45dd8
ALLM: 1
ColorMetry: 0xff
SCDC: 1
RR_Cap: 0
HDR/15 DeepColor
checkvalue: 0xd3bb0000
