maybe factory test board,i got them from sencond hand market 闲鱼.but many OTT box with S905X2-J/K can easily get.eg. tivo estream 4k.
Can you share a photo of the other side of the A311D board.
Hmmmmmm
Magic cube X1 V01 stamped on PCB
China only i think
Not available North America
Did the A311D board have Android installed? What is the fingerprint, can you grab the build prop (adb shell getprop)? If no Android, do you have a bootloader log?
[ro.bootimage.build.fingerprint]: [Droidlogic/MagicCube_X1/MagicCube_X1:9/PPR1.180610.011/20210518:userdebug/test-keys]
Maybe it was a prototype for a new Dreambox. The Dreambox One and Dreambox Two used an s922x.
Can anyone confirm that emmc high speed setting can be enabled on the minix u22 non max version.
i thougth i read somewhere here that hs200 is better option for u22-xj. because hs400 was causing stability issue’s
If you will try, so good luck with bootloop on minix u22xj! I tried 3 times and always i must recover with emmc-ce tools.
With this file you just revealed me that my Vivo XFold3 snapdragon 2e kodi or vlc and my laptop and my xiaomi x fold snapdragon 1er DO NOT SHOW DV FEL … "#$%?&*( I see many many effect that my old TV do not show me but NOT THE WOMEN AT THE END except my wife !!!
Are you sure that is not FEL ![]()
Fel is an extra layer.
Sometimes invisible.
As your wife.
When you see your wife, you have an
extra layer. ![]()
Extra Layer yes… well I have question about that all My TV Sony 4k is supposed to be HDR10 and Dolby Vision I see the HDR10 icon in CoreElec up left but not any DV info and I do not see it in Android/Kodi TV system nor any Dolby Vision excepted if I ask info it show me Dolby Vision or HDR10… How I can check the android TV system to be sure it does both ?
What is the Android box model?
S905X3 does not DV but my android10/Kodi TV system ?
There are DV licensed S905X3 SOCs, but your Android box probably doesn’t have one. You didn’t mention the name of the Android box model.
Yes sorry… its an T95MaxPlus S905x3 not licensed…
You can check out this thread for limited DV passthrough on nonDV licensed boxed.
