ng 21.3… but which file exactly out of all the available ones? Because I’ve used sc2_s905x4_4g_1gbit.dtb on the Dune HD Homatics Box R 4K Plus, and when I press play, I just get a black screen with no sound. I’ve used the 1.2 MB dovi.ok file, which is supposed to be for this player. I’ve also tried removing the dovi.ok file, and it does exactly the same thing… So which version should I use then??
First of all, make sure it’s called “dovi.ko” not “dovi.ok”.
The 1.2 MB one (1,290,671 bytes to be exact) is the correct one for the Dune. Which location did you copy it to?
“sc2_s905x4_sei_smb_280.dtb” << is the one to use for SEI804 (Dune) HD Homatics R Plus.
That last one was the one that wasn’t working for me… once I put in the 280.dtb file, it works now… thank you very much
Could have saved time and just read the first post in the beginning, it tells you to use that dtb already.
Has anyone compared FEL with CoreELEC vs. FEL with CSMC? ( [TESTING] Vero V: Dolby Vision FEL support - Testing - OSMC Forums and OSMC's May update is here with Dolby Vision FEL support - OSMC )
Update
Never mind, with the epic annoucement in Big surprise coming soon which I just read, I really don’t care about the alternative… CoreELEC rocks!![]()
This version is EOL an there is no more support
Maybe read time in forum should be increased before people can post. All is answered hundreds of times in forum…
Also, if you buy a RockTek G2 w/latest firmware, looks like only CE-NO works.
