You are saying you’re seeing scan lines and/or the DV layer “having an offset from the base layer” if I read it correctly? That must be something in your setup then, because for most of us, the Ugoos plays P7 FEL MKVs just fine without these issues.
What’s your setup exactly? Do you have an A/V receiver in your chain? Did you try a different HDMI cable? I cannot imagine this being a bug in CE, or it would have been reported much earlier already.
There isn’t anything unique to my setup that I can think of, my UGOOS is plugged in directly into TV via HDMI port 1, my TV is an LG OLED65C97LA, I have true HD color enabled and there isn’t any A/V receiver in the chain (I have an audio setup using eARC but that shouldn’t be effecting anything).
I am playing movies using PlexMod4Kodi, I also tried using SMB directly in Kodi but that didn’t make any difference. Is there anything else I should be looking out for?
EDIT: I also tried swapping out HDMI cables (no difference, also not expecting any here). Ontop of this I played the BL_EL.mp4 file and its also having the same scan line issues (further confirming its not how I am ripping the Blu Rays).
So I found the setting (its in Kodi → Settings → CoreELEC) and indeed setting it to player-led solved the issue, which I guess means that my TV cannot handle the FEL profile 7 Dolby Vision layer.
For the dev’s out there, maybe it makes sense to make the Player vs TV led setting specific based on what Dolby Vision profile is being played? I would gather that a lot of TV’s cannot handle the FEL profile 7 where as other profiles (like the ones from Disney+ or Netflix) can be handled without issues.
interesting, to my understanding there shouldn’t be that much difference between P7 FEL and MEL in the TV-led mode as FEL layer should be applied by the player in both modes (and TV just handles the RPU processing). Have you seen similar reports around here?
Strange… But I don’t think the issue is with the DV profile. The make and type of TV determines if TV-led is supported or not. With TV-led, the media player device sends an 8-bit RGB tunneled signal to the TV and the TV handles the DV processing. With player-led, the media player handles the DV processing and sends a 12-bit YCbCr 422 signal to the TV. But in both cases the FEL layer has already been processed by the media player.
I’m not sure if TV-led uses more HDMI bandwidth than player-led? In that case, your cable might still be the culprit.
So the issue is not the cable, I got a proper expensive cable that has been tested/certified to work with Dolby Vision by HDMI forum and there isn’t any difference.
So the context of me saying this is that I am able to watch Dolby Vision via Netflix without any issues and I assume that Netflix is not using P7 FEL, and that its also TV led.
Or in other words, I am only having issues with ripped Blu Ray Dolby vision DVD’s (and yes that includes the good remux’es).
CE-NG was never fully developed for the s905x4, although everything seemed to work fine when I tested any videos I threw at it.
Use one of the generic s905x4 dtb’s that corresponds to your box’s amount of RAM and ethernet. If the device has 4GB RAM + 1Gbit ethernet, use sc2_s905x4_4g_1gbit.dtb.
