I’been using with Libreelec (Raybuntu’s release) the Odroid C2 and CEC was working on the same setup.
Since switching to Coreelec 8.95.x, the CEC is not working any more.
I’ve tried:
- exchanging HDMI cables
- completely rewriting the img file.
The same cable works with different device, therfore it’s not a TV/HDMi cable problem.
The only clue that I could find in the logs are:
Jun 22 11:11:53 CoreELEC kernel: cectx c810023c.aocec: cec_ll_tx(): tx timeout
Sep 09 11:22:05 CoreELEC kernel: cectx c810023c.aocec: cec_ll_tx(): tx timeout
Sep 09 11:22:08 CoreELEC kernel: cectx c810023c.aocec: cec_ll_tx(): tx timeout
Sep 09 11:22:10 CoreELEC kernel: cectx c810023c.aocec: cec_ll_tx(): tx timeout
Sep 09 11:22:12 CoreELEC kernel: cectx c810023c.aocec: cec_ll_tx(): tx timeout
Here’s the EDID information:
Jun 22 11:11:49 CoreELEC kernel: EDID Parser:
Jun 22 11:11:49 CoreELEC kernel: hdmitx: get dtd0 vic: 97
Jun 22 11:11:49 CoreELEC kernel: hdmitx: get dtd1 vic: 16
Jun 22 11:11:49 CoreELEC kernel: hdmitx: edid: find IEEEOUT
Jun 22 11:11:49 CoreELEC kernel: hdmitx: edid: check sum valid
Jun 22 11:11:49 CoreELEC kernel: hdmitx: update rx hdr info 5 at edid parsing
Jun 22 11:11:49 CoreELEC kernel: hdmitx: edid: blk0 raw data
Jun 22 11:11:49 CoreELEC kernel: 00ffffffffffff004c2df70d000e0001011b0103807944780a23ada4544d9926
0f474abdef80714f81c0810081809500a9c0b300010108e80030f2705a80b058
8a00501d7400001e023a801871382d40582c4500501d7400001e000000fd0018
4b0f873c000a202020202020000000fc0053414d53554e470a20202020200165
Jun 22 11:11:49 CoreELEC kernel: hdmitx: edid: blk1 raw data
Jun 22 11:11:49 CoreELEC kernel: 020353f05761101f041305142021225d5e5f606566626364071603122c090707
1507503d04c057070083010000e2000fe305c3016e030c003000b83c20008001
02030467d85dc401788003e3060d01e30f01e0011d80d0721c1620102c258050
1d7400009e662156aa51001e30468f3300501d7400001e00000000000000003f
