Moved to Coreelec from Raybuntu’s C2 Libreelec builds. I noticed that on the coreelec build there is noway to control when CEC powers off the system after an idle time.
Granted Ray’s builds were kodi 17 and this is now 18.
Under System -> Input Devices -> Peripherals -> CEC adapter.
I am not sure if this is just a change in kodi 18, however if it is coreelec specific is there a workaround for this or reason its missing in the current C2 builds?
It is possible to start coreelec TV box via hdmi cec? I want the TV box to turn on when I turn on the TV. otherwise the hdmi cec function works properly and shut down works too
