Hi,Amlogic-ng install with existing installtointernal - #3 by Sirfon
I am running for years CoreELEC. My Z69-box stems back from the old LibreELEC days and the old installtointernal
method. Thank you very much. Great Work by you.
It currently runs CoreELEC 9.2.8 non-nextgen
With the CoreELEC Omega 21.0-ng I considered a new installation, used it on a new SD-card and everythings works fine. I can switch easyl between both installations just be releasing/inserting the SD-card. Great.
Now I want to install this new CoreELEC-ng to internal to use the 32GB internal storage, use the sd card for interchangeble storage und release the sd card from the potential wear of filesystem operations.
I want to install the configured CE 21.0-ng to internal EMMC as a Single boot option. There is no Android left on the device.
When i boot the new system from SD it unfortunately doesn’t find the existing CE install and does not offer to install over it. Only dual boot is offered.
CoreELEC:~ # ceemmc -vx
Starting CoreELEC eMMC installation tool…
System is not supported: gxl_p212_3g!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: yeMMC size: 0x000747c00000 [32GB]
Original partition table:
[mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000 [4 MB], unkn
[mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000 [64 MB], unkn
[mmcblk0p03] cache offset 0x000006c00000, size 0x000020000000 [512 MB], cache
[mmcblk0p04] env offset 0x000027400000, size 0x000000800000 [8 MB], unkn
[mmcblk0p05] logo offset 0x000028400000, size 0x000002000000 [32 MB], code
[mmcblk0p06] recovery offset 0x00002ac00000, size 0x000002000000 [32 MB], code
[mmcblk0p07] rsv offset 0x00002d400000, size 0x000000800000 [8 MB], code
[mmcblk0p08] tee offset 0x00002e400000, size 0x000000800000 [8 MB], code
[mmcblk0p09] crypt offset 0x00002f400000, size 0x000002000000 [32 MB], code
[mmcblk0p10] misc offset 0x000031c00000, size 0x000002000000 [32 MB], code
[mmcblk0p11] instaboot offset 0x000034400000, size 0x000020000000 [512 MB], code
[mmcblk0p12] boot offset 0x000054c00000, size 0x000002000000 [32 MB], code
[mmcblk0p13] system offset 0x000057400000, size 0x000040000000 [1024 MB], code
[mmcblk0p14] data offset 0x000097c00000, size 0x0006b0000000 [27392 MB], dataNo CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
Use CoreELEC data from
[2] existing backup on current used SD or USB deviceInstall in single boot mode not possible!
Please choose one option? [1/2]:
When I start the old internal CE 9.2.8 I have no ceemmc
command it only features installtointernal
Do you have any ideas, how to circumvent this? It appears such ideas have been asked before but not answered yet.
Thank you very much for your time
krelmatrix
