Hello, I would like to use my ugoos with coreelec with my capture card. unfortunately it can’t do 12bit
how can I set the color depth to 10bit? kind regards
Settings > System > Display > Force display colour depth > 10bits
Is this for GUI only?
For TV-led DV content or HDR it will still switch to the appropriate bit during playback?
That setting forces the color depth to the specified value for both UI and all video content (HDR10 and HDR10+ too). The settings change doesn’t kick in until there is a display resolution or refresh rate change. It doesn’t apply to player or tv-led DV.
There does appear to be a bug when exiting a DV video, the color depth is set back to 12bit until the next video display settings change.
@YadaYada congratulations on becoming a moderator! ![]()
