Change Path Addons_data
Hello friends, I would like to change the directory “addons_data” (installed in the internal memory) to a microSD, how could I do it? I’m a noob
Unless you have a developer board ???
No, I do not have. Thanks for the reply, I will try with a symbolic link or i or modify advanced setting
but I do not think I’ll get it. Anyway, thanks
The sym link method should work.
You can play also with:
Path substitution
Thanks fo the reply. I Use to change “addons_data”
Sin%20t%C3%ADtulo
This dont work for me.
Finally, I’ve got it. Using sym link. Thanks for all
@ercalipo canyou please help me , coreelec is installed on emmc ,i want to symlink user data folder to an usb pendrive (formatted to ext4) ,can you guide me the steps.
