I am new in CoreELEC, I come from LibreELEC.
I upgrade with CoreELEC-S905.arm-8.90.1.img.gz and do a hard reset and start to configure my S905 device.
All works fine, but I don’t know how to configure the remote keymap.
In LibreELEC I use to modify those files to get my remote working as I want:
nano /storage/.kodi/userdata/Lircmap.xml
<!-- <menu>KEY_MENU</menu> -->
<title>KEY_MENU</title>
nano /storage/.kodi/userdata/keymaps/remote.xml
<!-- <power>ShutDown()</power> -->
<power>System.Exec("/storage/cecpower.sh")</power>
How could I configure this in CoreELEC?
Thanks for your great work.
Kind regards.
Lirc does not work in the kodi version included in 8.90.1. it will be fixed in 8.90.2
Thanks!
I will be waiting for it.
Best regards.
I upgrade to 8.90.2 but there is no /storage/.kodi/userdata/Lircmap.xml file.
There is /storage/.kodi/userdata/keymaps/remote.xml and it works well.
How could I change the KEY_EPG and KEY_MENU keys? I want to configure this way:
<recordedtv>KEY_EPG</recordedtv>
Thanks and kind regards.
You can try KEY_PVR instead of KEY_EPG
<recordedtv>KEY_PVR</recordedtv>
See end of my post for default mapping links
X92 remote example
Thanks boot2k3,
But where could I change this? In which file?
Kind regards.
Please check How to section, all info about configuration available there and example in link I gave you before.
[HowTo] Configure IR remote control
[HowTo] Remote Control Configuration for Dummies Using Windows and SSH
You need to assign correct remote key mapping in your remote config or change action for button
