Is it possible to change the wireless network mode on the network adapter, using CoreELEC?
I’m using an H96 Max X3 android box and the adapter uses 802.11ac by default. But I noticed that my pc gets a more stable connection with 802.11n, so I would like to try the same with CoreELEC.
Edit: I installed the network tools addon and connected through ssh to do the “iwlist modu” command, which returns “unknown modulation information”
I checked the documentation for iwconfig, and I see that:
“The list of available modulations depend on the card/driver and can be displayed using iwlist modulation . Note that some card/driver may not be able to select each modulation listed independently, some may come as a group. You may also set this parameter to auto let the card/driver do its best.”
So if iwlist returns unknown modulation, I’m not sure what parameter to use with “iwconfig modu”, to be sure it will be supported on my device.
