Hi
have the new chromecast with google tv here.
The Hardware should be fine for CoreElec.ng
I have connected a USB C Hub with Ethernet LAN and a Stick with CoreElec.ng on it.
But how to get the device into recovery mode to boot from USB ?
Any hints or ideas ?
What device exactly do you have?
If it has L1 DRM (most original Google devices have it) than you have a locked bootloader, and if so, no way to get CE running on that device…
For this one I’m 99.99% sure that it has locked boot loader…, but there is still 0.01% chance that it’s possible to install CE on it
99,99 is enough to give it back
because german magenta tv stick (with Widevine Level 1) can reboot with build in update app and is fine with CoreElec.ng - and is 20 Euro cheaper…
No root, enrypted bootloader - no CE
system
Closed
23 January 2021 19:21
7
