Cleaning Videolibrary causes issues
i have post this issue to Kodi forum in here
https://forum.kodi.tv/showthread.php?tid=383154&pid=3246483#pid3246483
and i was told that propably is a Coreelec issue.
i describe my problem
am using Coreelec..
Really big library, Ugoos Am6b+ connected via Gigabit Lan to Windows 10 machine that has my library. (SMB)
when i try to clean my movie library (only movies not tvshows), kodi does this..
In my Animeshows folder (contains tv shows) - all appear with 0 episodes..
and in my docstv folder (tvshows) - although as source it was set for tvshows… after the clean it was set to None…
Log is too big and had to put it in here
updated coreelec to 21.3 stable, run the update library and the clean library.
Nothing weird happened…
if it happens again, will report back…
