Compile Issue
I forked the project at https://github.com/CoreELEC/ap6xxx-aml and modified some parts of the code. When compiling with the CoreELEC project, I replaced PKG_VERSION, PKG_SITE, and PKG_URL, but I keep encountering errors during compilation. Could you please advise on how to resolve this issue?
Fix the errors you get?
Because you didn’t provide any other info this is all you can get.
# SPDX-License-Identifier: GPL-2.0
# Copyright (C) 2017-2018 Team LibreELEC (https://libreelec.tv)
# Copyright (C) 2018-present Team CoreELEC (https://coreelec.org)
PKG_NAME="ap6xxx-aml"
PKG_VERSION="e9bc18378a1c155511754f04ef695c5b9551962a"
PKG_SHA256=""
PKG_ARCH="arm aarch64"
PKG_LICENSE="GPL"
PKG_SITE="https://github.com/simonhust/ap6xxx-aml"
PKG_URL="https://github.com/simonhust/ap6xxx-aml/archive/${PKG_VERSION}.tar.gz"
PKG_DEPENDS_TARGET="toolchain linux"
PKG_NEED_UNPACK="${LINUX_DEPENDS}"
PKG_LONGDESC="ap6xxx: Linux drivers for AP6xxx WLAN chips used in some devices based on Amlogic SoCs"
PKG_IS_KERNEL_PKG="yes"
PKG_TOOLCHAIN="manual"
pre_make_target() {
  unset LDFLAGS
make_target() {
  echo
  echo "building ap6356s and others"
  kernel_make -C  ${PKG_BUILD}/bcmdhd.1.363.59.144.x.cn \
       PWD=${PKG_BUILD}/bcmdhd.1.363.59.144.x.cn \
       KDIR=$(kernel_path) \
       ARCH=${TARGET_KERNEL_ARCH} \
       CROSS_COMPILE=${TARGET_KERNEL_PREFIX} \
       CONFIG_BCMDHD_DISABLE_WOWLAN=y \
       dhd
  if [ "$DEVICE" = "Amlogic-ng" ]; then
    echo
    echo "building ap6275s"
    kernel_make -C  ${PKG_BUILD}/bcmdhd.100.10.545.x \
         PWD=${PKG_BUILD}/bcmdhd.100.10.545.x \
         bcmdhd_sdio
    echo
    echo "building ap6275p"
    kernel_make -C  ${PKG_BUILD}/‎bcmdhd.101.10.361.x \
         M=${PKG_BUILD}/‎bcmdhd.101.10.361.xx \
         PWD=${PKG_BUILD}/‎bcmdhd.101.10.361.x \
         KERNEL_SRC=$(kernel_path) \
         CONFIG_BCMDHD_PCIE=y \
         bcmdhd_pcie
  fi
makeinstall_target() {
  mkdir -p ${INSTALL}/$(get_full_module_dir)/${PKG_NAME}
  find ${PKG_BUILD}/ -name \*.ko -not -path '*/\.*' \
    -exec cp {} ${INSTALL}/$(get_full_module_dir)/${PKG_NAME} \;
post_install() {
  if [ "${PROJECT}" = "Amlogic" ]; then
    rm ${INSTALL}/usr/lib/modprobe.d/dhd_sdio.conf
    rm ${INSTALL}/usr/lib/udev/rules.d/80-dhd_sdio.rules
  fi
I don’t see any error here :thinking:
Maybe need a make clean… EEOR LOG,
2025-11-21 16:07:29 (412 KB/s) - '/home/glsimon/CoreELEC/sources/ap6xxx-aml/ap6xxx-aml-e9bc18378a1c155511754f04ef695c5b9551962a.tar.gz' saved [12333374]
    INFO      Calculated checksum: 07ed691c2a3d45ee2b116104edc15163e4fee6971ad12d78e13ac22d7bcb6684
CLEAN      ap6xxx-aml
    *      Removing /home/glsimon/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/ap6xxx-aml-c952e40780e1278a5fe2105acf6d6f1622ea4a9b ...
    *      Removing /home/glsimon/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/install_pkg/ap6xxx-aml-c952e40780e1278a5fe2105acf6d6f1622ea4a9b ...
    *      Removing /home/glsimon/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/qa_checks/ap6xxx-aml-* ...
UNPACK      ap6xxx-aml
BUILD      ap6xxx-aml (target)
    TOOLCHAIN      manual
make[1]: Entering directory '/home/glsimon/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/ap6xxx-aml-e9bc18378a1c155511754f04ef695c5b9551962a'
make[1]: *** /home/glsimon/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/ap6xxx-aml-e9bc18378a1c155511754f04ef695c5b9551962a/bcmdhd.1.363.59.144.x.cn: No such file or directory.  Stop.
make[1]: Leaving directory '/home/glsimon/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/ap6xxx-aml-e9bc18378a1c155511754f04ef695c5b9551962a'
FAILURE: scripts/build ap6xxx-aml:target during make_target (package.mk)
*********** FAILED COMMAND ***********
kernel_make -C ${PKG_BUILD}/bcmdhd.1.363.59.144.x.cn PWD=${PKG_BUILD}/bcmdhd.1.363.59.144.x.cn KDIR=$(kernel_path) ARCH=${TARGET_KERNEL_ARCH} CROSS_COMPILE=${TARGET_KERNEL_PREFIX} CONFIG_BCMDHD_DISABLE_WOWLAN=y dhd
${SCRIPTS}/build "${1}" "${PARENT_PKG}"
FAILURE: scripts/install ap6xxx-aml:target has failed!
The following log for this failure is available:
  /home/glsimon/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/.threads/logs/128.log
>>> ap6xxx-aml:target seq 128 >>>
[361/363] [FAIL] install ap6xxx-aml:target
Parallel build failure - see log for details. Time of failure: Fri Nov 21 16:07:33 CST 2025
make: *** [Makefile:7:release] 错误 1
Fro CE-21 branch you need to use p-amlogic branch for ap6xxx-aml but you used 5.15.170.
:grinning_face: okay,i will try it.
