Hello I’m struggling to compile add-on Tvheadend4.3.
What i did: (Ubuntu 22.04, with Instructions from wiki coreelec build ce)
PROJECT=Amlogic-ce ARCH=arm Device=AMLGX scripts/build libdvbcsa scripts/create_addon tvheadend43
After fifty minutes (core-i3) the compilation ends with the message:
Cannot get zlib sources : http://zlib.net/zlib-1.2.12.tar.xz try later!
I think the current version of zlib is 1.2.13.
wget http://zlib.net/zlib-1.2.13.tar.xz
works.
So I installed that version und started the compilation again. But the error message remains.
Is there a way to change the zlib version
1.2.12 to 1.2.13?
Oh du I have to compile the whole CoreELEC Image first?
I assume this LE commit zlib: update to 1.2.13 · LibreELEC/LibreELEC.tv@a265d5f · GitHub will make it to CE and make your life easier
Thanks a lot. That did the trick.
But compiling isn’t that easy.
I startet the compilation with so many different parameters. Always (other) errors at the end.
For a 905 (Mecool KI pro and wetek play 2, Matrix RC-2) amlogic device, what are the working parameters when you consider this thread?
But thanks anyway, this was a very useful hint!
Trying to build tvheadend with patched libdvbcsa.
ends with these errors:
Building in LibreELEC.tv works.
Thank you
vpeter
5
Without little more info no one can tell you what is wrong.
And btw: How did you get AMLGX device? CE19 only has Amlogic-ng device.
That helped. I put the patch into the /packages/devel/m4/patches folder.
now it compiles the tvh43 addon witout any errors.
system
Closed
7
