Make a clean install:
ERROR <general>: Unable to find plugin script.skin.helper.service
Please follow the steps:
https://wiki.coreelec.org/coreelec:troublesteps#before_posting_an_error
script.skin.helper.service is deactivated, it was a clean install, then i copied from my rc1 backup the addons. Can really this should be the problem with my issue? If yes, then i will follow your recommendation.
Sorry if this is not the right place but I can’t get an answer after 5 days to my question here;
When I press a key on my RC, CE takes multiple same actions, for exemple if I move in a list, it will jump to 5-9 items further.
I’d guess there is a place where one can set de delay between actions. Where?
Disable CEC and check. It helped with my box.
Please all update first to 19.4-Matrix_rc3 and if the issue is not resolved continue here:
