The last thing here is to try 2 different dtb files. Make SD card with RC1, update to RC2, when it fails booting only replace dtb.img with first and if doesn’t boot with second.
tried both. Neither worked.
Then sadly I don’t know what is going on.
Because we really need dmesg from not working system let’s try this.
Boot from RC1, update to RC2, you get to shell. Wait a minute and attach USB stick.
Then save dmesg to USB stick and post this dmesg file from USB stick you will get.
mkdir m
mount /dev/sda1 m
dmesg >m/dmesg_user
sync
# check that you really have something in the file
# if not repeat dmesg and sync
less m/dmesg_user
umount m
# power off device
For now we don’t see any solution to this problem. Google suggest to use some different SD card in this case. Like from different manufacturer, size, …
Thanks. Just trying to help.
For now I will stay on RC1 of my SD card. I have tried two other new installs of RC2 on other SD cards and same exact issue.
The workaround for now, which I am not using, would be to use USB stick with RC2 installed as that is flawless.
Motoviper, you can try to use ceeemc. But as always you have to be prepared to reflash Android in case something goes wrong.
You could try to enable Disable GUI scaling in CE settings
I tried that, but as I understand it’s still very experimental. For me, it just displays the whole UI in the top-left quarter of the screen, leaving the rest of the screen blank.
For quarter display issue follow this instruction
It’s working feature but GUI interface could be slowly and boot logo could be distorted if you use native 4K GUI(not while watching)
But thank you for issue, we will check… I could repeat it when scaling used.
Thanks. I have switched back to 19.3 for now.
I have same issue. 19.3 upgraded to 19.4 RC2
How did you downgrade? I replaced kerrnel.img and SYSTEM of 19.3, but not works.
Pls, help me!
Thx
You should also replace dtb file. if you have not booting box issue.
What issue and what box do you have?
If you have scaling issue then just normal update is possible
https://wiki.coreelec.org/coreelec:updates
I have exactly the same problem. UI elements look blurry as hell when playing anything 4K. It wasn’t like this with 19.4-Matrix_rc1. I’m also using a S905X3 box (X96 Max+).
Hi All,
just wanted to share my test results:
19.3: works flawlessly with every file
19.4 RC2: very slow player, no image and sound cuts
With 19.4 RC2 I have the exact same behavior as I had with Nightlies:
I’m on N2+ 4Go with CE on SD Card.
Could you try clean install for 19.4 RC2 on some different USB/SD card for test and don’t attach external devices if exist?
We couldn’t repeat it on N2 or N2+
If it doesn’t work, then collect full log.
If it works, then plug devices until you repeat this issue.
It looks like locked decoder… but don’t know reason for this.
Ok, not sure I can test it soon but I’ll let you know if I can.
I actually have external devices connected to usb: wifi dongle 5B and 1To HDD
Is it recommend to unplug all the devices when performing a clean install of CE?
Just updated from 19.3 on Odroid N2. I can’t get Tvheadend to work. It seems something to do with the Addon. Coreelec repo shows as 19.4 but Tvheadend 4.2 only shows as 19.3.125. If I run check for updates, kodi restarts after some time but nothing is found.
Can anyone help me with the way forward on this? I’ve deleted packages and the coreelec repo from Kodi/addons to no effect when trying to check for updates.
Reverting to 19.3 for now
No, it’s just to be sure…
As you tried different images then I think we could exclude broken file.
Or it’s some hw check failed that was ignored before in old kernel.
