Tried to get the debug info for half an hour starting recordings (SD->HD->SD etc).
Weirdly enough, the issue does not occur at all while in debug mode. Turned off debug mode and it happened within the first couple of tries.
This is what the crashlog said:
2022-05-03 22:03:36.758 T:4958 INFO <general>: Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (16) (weight: -270675410944.000)
2022-05-03 22:03:37.397 T:5121 INFO <general>: CActiveAEStream::AddData - messy timestamps, increasing interval for measuring average error to 2168 ms
2022-05-03 22:03:38.054 T:5516 ERROR <general>: GetDirectory - Error getting
2022-05-03 22:03:38.074 T:5060 INFO <general>: AddOnLog: pvr.dvblink: Found 63 recordings
2022-05-03 22:03:38.837 T:5516 ERROR <general>: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/9/9999393d.jpg
2022-05-03 22:03:39.217 T:4958 INFO <general>: [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 50.000, 3D: false
2022-05-03 22:03:39.218 T:4958 INFO <general>: Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (16) (weight: 0.000)
2022-05-03 22:03:39.247 T:4958 INFO <general>: VideoPlayer::OpenFile: pvr://recordings/tv/active/Doctor Who/Doctor%20Who (1969), TV%20(BBC%20One%20HD), 20211205_182004, 8F94B459-EFC0-4D91-9B29-EC3D72E92677:F6F08949-2A07-4074-9E9D-423D877270BB/7-13576733226387993080-1638728400.pvr
2022-05-03 22:03:39.256 T:5896 WARNING <general>: OutputPicture - timeout waiting for buffer
2022-05-03 22:03:39.256 T:5516 INFO <general>: Deleting settings information for files pvr://recordings/tv/active/Doctor Who/Doctor%20Who (1969), TV%20(BBC%20One%20HD), 20220101_190004, 8F94B459-EFC0-4D91-9B29-EC3D72E92677:F6F08949-2A07-4074-9E9D-423D877270BB/7-13576733226387993080-1641063600.pvr
############### END LOG FILE ################
############ END kodi CRASH LOG #############
No idea why its looking for a whitelist (not using it) or why things would stall in a high speed local network. And any issue with playback should never crash Kodi imho.
Well this is interesting, after using a 100% unmodified install. There is no WiFi at all. No 5GHZ, no 2.4. Nothing at all.
Tried rebooting after the initial install. Still no WiFi connections available.
For the record this is an A95X (S905x) box.
Thoughts?
Looks like this update broke auto suspend on my khadas vim 3. I use the turn off screensaver which suspends my vim 3 after 10 minutes, but now it always stays on and I hear the fan spin regularly. Does anyone have the same issue?
Hi
I had already installed CoreELEC 19.4 on the memory card. A few days ago, when I turned on my Android box and entered CoreELEC, the system was automatically upgraded to CoreELEC 19.5.
After booting the system, when I entered the settings, the CoreELEC 19.5 version was inserted.
Is this upgrade fully done?
Or do I need to manually make some settings?
Hi, Developers
19.5 rc1 changelog shows “Fixed h264 on some media not fluently displayed”
I have this one file cannot be played fluently.
I tryed software decode & hardware decode, neither played correctly.
Using Plex on SHIELD TV Pro it worked out perfectly.
My device is MINIX NEO U22-XJ MAX running CoreELEC 19.5-Matrix_rc1
Here’s the download link & Mediainfo: https://drive.google.com/file/d/1YpK_ksVIDg-xUBhbKdvMUMIlpzrmiJHL/view
Format : Matroska
Format version : Version 4
File size : 1.26 GiB
Duration : 5 min 36 s
Overall bit rate : 32.2 Mb/s
Encoded date : UTC 2022-02-10 15:34:36
Writing application : mkvmerge v64.0.0 (‘Willows’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 4:2:2@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 4 frames
Format settings, GOP : M=4, N=32
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 31.7 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 50.000 FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 10 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.306
Stream size : 1.24 GiB (98%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : A_MPEG/L2
Codec ID/Hint : MP2
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Compression mode : Lossy
Delay relative to video : 134 ms
Stream size : 7.71 MiB (0%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : MPEG Audio
Codec ID/Hint : MP2
Bit rate : 192 kb/s
Delay relative to video : 126 ms
Language : English
Default : Yes
Forced : No
Audio #3
Format : MPEG Audio
Codec ID/Hint : MP2
Bit rate : 192 kb/s
Language : English
Default : Yes
Forced : No
Has something changed, reasonably recently (last few weeks to couple of months) - about the way CoreElec or Kodi handle HDR detection & triggering and the start of playback?
(I’m currently on nightlies for 19.5)
I have noticed in recent times, on several occasions, that HDR is not triggered on my TV for HDR files (or occasionally the wrong HDR - e.g. PQ instead of HDR10+ for example, or vice versa, is triggered). The same file, played and stopped multiple times in a row, will not trigger HDR then randomly suddenly do so.
I’m not exactly sure when this began (my collection only has a relatively small amount of HDR in it) - and will, on the weekend, look at trying a few older versions and begin to gather logs, but I first wanted to see if anyone else has been having difficulties (CE on N2+, via Denon AVR X2700h to Panasonic OLED)
Please check and if you find any problemática file please upload a small sample somewhere so we can check. I didn’t have any problems and just yesterday went through lots of samples with HDR/HDR10+/HLG
I had no audio even using 20220505 (and newer) nightly in my K1 Pro.
Comparing my kodi logs in 20220416 nightly with newer builds, I found no event “Enumerated ALSA devices” happened.
After some attemps to fix this I discovered after stopping pulseaudio and restart of kodi.service, kodi finds ALSA devices. So I did masking of pulseaudio as workaround: systemctl mask pulseaudio.service
It seems this issue is unique for my setup as I found no other similar reports. Maybe I have something wrong in my installation or setup. Therefore no other actions are required for me
