20.5 still gets stuck loading HD media on my N2+'s. Same issue as 20.4
Rolled back to 20.3 and all is good.
Thanks for release
silly question perhaps : is CoreELEC 20.5-Nexus marked orange Pre-release (as opposed to green Latest) on purpose?
Yes, we wait until there are a certain number if updated devices and no major bugs to release it for auto update.
OK … I will install on 4 different devices and will report any issues.
Hi, Is there any solution for this error in the screenshot above?
NG and NG-DV is already online. NE should be tomorrow.
No, you will just be patient until Amlogic-ne/20.5/aarch64/ get available:
https://github.com/CoreELEC/CoreELEC-Addons/branches/all
Thank you for your clarify. I hope to get it soon.
I am seeing this but for the kodi repo…
I’m facing this matter with my Kodi skin, every startup the kodi this message pop up, when I tried to download this addon from Coreelec repository, kodi couldn’t connect to repository!
@Damas007: Should work now. Let us know if there is still issue and post kodi log in this case after fresh boot.
Thank you so much @vpeter worked.
Have you solved this ? Is is working for you at this moment ?
