CoreELEC 21.0-Omega_beta3 Amlogic-ng Discussion
Amlogic-ng
Please use this thread for general CoreELEC 21.0-Omega_beta3 Amlogic-ng discussion
Hello Coreelec Team,
I have fresh installed the coreelec-21-0-omega-beta3-amlogic-ng in my x96 mini+, and i lost wifi on them.
I make some logs in hope you can help others and me on this position.
The result for dmesg | paste
https://paste.coreelec.org/kzSsz3
udevadm info /sys/bus/sdio/devices/* | paste
https://paste.coreelec.org/8pUaef
Will need to check it:
[ 10.347459@3]- vlsicomm: Unknown symbol __aarch64_ldadd4_sync (err 0)
Thank you @Portisch
I´m gonna test a few devices i have and post the results, i have install a fresh install in Mecool KII Pro, and this one missing the wifi and the tunner, here´s the logs i´ve made:
dmesg | paste
https://paste.coreelec.org/h1cYMC
https://paste.coreelec.org/W14Vct
The SDIO_ID=8888:8888 should be fixed in tomorrow Amlogic-ng nightly again.
X96 Max+ fresh install
missing the wifi to
Here´s the log´s:
dmesg | paste
https://paste.coreelec.org/aPX3EW
https://paste.coreelec.org/SuTkzc
@Portisch
I inform all devices i mentioned in here, is all fix with last nightly build, i test:
X96 Max+
Mecool KII Pro (the tuner is working)
X96 Mini+
A95X
X99
Thank you to all the Team.
Can I ask how you got the tuner working on the k11 pro?
Yes you can @Mark22,
I made a fresh install, then you must install the DVB latest kernel drivers and i´m install too the DVB drivers for TBS, reboot and after that, voilá, in tvheadend you allready see the tuner.
I hope you can get it.
in the last building i try CoreELEC-Amlogic-ng.arm-21.0-Omega_nightly_20240225 the wget is working in http, but not in the ftp protocol.
I give some example:
CoreELEC:~ # wget -c ftp://demo:password@test.rebex.net:21/readme.txt
wget: not an http or ftp url: ftp://demo:password@test.rebex.net:21/readme.txt
i try in the Nexus 20.2 and work´s great.
Use curl instead of wget? I think wget doesn’t have enabled ftp protocol.
Thanks @vpeter,
You right :index_pointing_at_the_viewer: :+1: :slightly_smiling_face:
With curl work like a charme.
With the daily updates for CoreELEC NG versions on March 9 and 10, the DVB drivers do not work on GT King Pro.
works on nightly versions given on March 4
Linux version 4.9.269
Wireless doesn’t work on CoreELEC NO versions either.
Wireless option does not appear in the network section of CoreELEC settings menu.
Linux version 5.15.119
Question: is a rc1 version underway?
Came to check the release but can’t see it
The nightly of March 9th was bumped to RC1. You can find it in the archive folder of CoreElec nightly builds.
https://relkai.coreelec.org/?dir=Amlogic-ng/ce-21/archive
Was trying to stay clear of the nightlies, might circle back, thanks
Closed,
continue here CoreELEC 21.0-Omega_rc1 Amlogic-ng Discussion
