CoreELEC 22.0-Piers_rc1 Discussion
OK, you are right.
The Kodi team has made a mess of the folder names and the welcome screen. :slight_smile:
The fix is working well! Confirmed to be fixed both in the native player and the small mkv test clip i uploaded via winscp to the eMMC as well as over my gigabit network from my plex server using the PM4K addon. Confirmed not just the problem test clip part of one song but numerous other areas in this same bluray concert that also showed the issue, all are good now.
I was struggling to reproduce skips on some of the 48khz high audio bitrate content that others had referenced in those previous links I included (Free Guy, Pirates of the Caribbean 5). Altho once I did have a crash in the first 2min intro scene on Free Guy where the player closed and kicked me back to the main plex menu, but I couldn’t repeat it. From my understanding theres enough error correction / on the fly handshake adjust that receivers can do to make up for some of the frame errors on 48khz but on 96khz its much less forgiving. I also have a Dave Matthews Band Live at Radio City 96khz 24bit bluray concert disc that I had only 1 or 2 skips but again not consistent like the John Mayer concert (possible the bitrate isn’t quite as high, still running thru the last hour of the concert) . I’ll try to do more testing later tonight (easy enough to reboot and run the unpatched vs the mount command to test the patched) and report back. Thanks again, truly appreciate you finding the root cause here. This CoreELEC box can now serve as my pure DV FEL + passthru audio box of choice it appears :slight_smile:
Since I always passthru its not a concern to me, but the lack of decoding to multiCh PCM when selecting 5.1 or 7.1 speaker config and disabling passthru still may need some attention tho (zero output in those situations)
Closed, continue here: CoreELEC 22.0-Piers_rc2 Discussion
