Hello, I have a TV box of type X96 M200 4 GB / 32 GB, with CoreELEC 22.0-Piers
How can I install Transmission torrent client on it?
or
docker
I would rather recommend install the qbittorrent to docker.
Entware qbittorrent install
SSH:
installentware
after install
reboot
opkg install qbittorrent
reboot
stop Qbittorrent service:
.opt/etc/init.d/S89qbittorrent stop
navigate to
/.opt/etc/qBittorrent_entware/config folder
File/Edit
qBittorrent.conf file
we insert it at the end of the list:
WebUI\Password_PBKDF2=“@ByteArray(ARQ77eY1NUZaQsuDHbIMCA==:0WMRkYTUWVT9wVvdDtHAjU9b3b7uB8NR1Gur2hmQCvCDpm39Q+PsJRJPaCU51dEiz+dTzh8qbPsL8WkFljQYFQ==)”
(source: [BUG] the 4.6.1 release breaks the web ui login · Issue #268 · linuxserver/docker-qbittorrent · GitHub
start Qbittorrent:
.opt/etc/init.d/S89qbittorrent start
WebUI:
COREELEC_BOX_IPaddress:9080
Username: admin
Password: adminadmin
What command can I use to enter here?
Browse to the folder, for example under windows.
Use WinSCP program for that (e.g.)
use this
Log in to your box
192.168.2.234
And browse to the folder I mentioned
Thank you! It’s working!
