After update CoreELEC 8.90.1 to 8.90.3, when i choose 1920*1080 resolution, i have low fps, someone with the same problem?
It would be helpful if you could provide what you are playing ie the codecs being used, and of course a debug log.
But best to first install the new version 8.90.4 and see if that fixes the problem.
Cheers
Gary
Have you enabled resolutions and frame rates in Whitelist? I’m guessing not.
