Hi there.
It seems that there is some kind of issue with my Mini M8s II CoreElec installation, regarding the Library Scanning. The issue had surfaced with CE 9.2.6, too.
Here is some info:
I installed 9.2.6 from the start (no restored backup, only a pasting of my previous passwords.xml and the SMB sources.xml within the Usedata folder). The installation of 9.2.6 was done on a different newly formatted microSD card. The card is a 16 GB Lexar U1 Micro SD. After a few days 9.2.7 was released so I updated. I do remember not having this issue with 9.2.5 and prior.
My SMB shares are two USB hard disks plugged to my Fritz Router.
I have enabled scanning at startup. It seems like it starts the scanning and it stays at 0%. If I go manually to “update video library” sometimes it does nothing and other times it starts scanning but it is very slow. I have tried with 3-4 different metadata services (TVDM, The Movie Database, The Movies Database Python, etc). Last night I cleaned the library and left it all night to scan from the beginning.
When I woke up it still hadn’t scan all the library. I seemed like it was stuck at 100% of some TV Series. -
I also tried with disabling scanning at start up. Didn’t help. I also have Watchdog add on installed. Does not help.
In both Windows 10 Kodi and CE Kodi I have SMBv2 as minimum and SMBv3 as max.
With my CE box I have tried with lan cable connected directy to my box’s 100 ethernet port, and I have also tries with my CE supported TP-Link UE300 USB 3.0 to LAN adapter (Realtek 8153 chipset). No change there. Same issue.
My Windows PC Kodi 18.9 sees the same SMB sources and has no issues at all ! It always scans without issues when Kodi starts. It also works fine when I manually go to “update video library”.
So it seems that the problem is with my CoreElec intallation only, but I cannot find what’s wrong.
I do see some errors within the Kodi log but I cannot understand what they mean. Here is a sample:
2021-03-20 08:45:34.960 T:4022330240 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=T%20V%20S%20%20%20A%20R%20C%20H%20I%20V%20E%20S:
2021-03-20 08:45:34.960 T:4022330240 ERROR: Run: Unable to parse web site
2021-03-20 08:45:35.061 T:4022330240 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=T%20V%20S%20%20%20A%20R%20C%20H%20I%20V%20E%20S:
2021-03-20 08:45:35.061 T:4022330240 ERROR: Run: Unable to parse web site
2021-03-20 08:45:35.062 T:4022330240 WARNING: No information found for item 'smb://192.168.178.1/FRITZ.NAS/INTENSO/Video/TV Series/T V S A R C H I V E S/', it won't be added to the library.
2021-03-20 08:45:35.718 T:4022330240 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=T%20V%20S%20%20%20W%20A%20T%20C%20H%20I%20N%20G:
2021-03-20 08:45:35.719 T:4022330240 ERROR: Run: Unable to parse web site
2021-03-20 08:45:35.809 T:4022330240 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=T%20V%20S%20%20%20W%20A%20T%20C%20H%20I%20N%20G:
2021-03-20 08:45:35.809 T:4022330240 ERROR: Run: Unable to parse web site
2021-03-20 08:45:35.810 T:4022330240 WARNING: No information found for item 'smb://192.168.178.1/FRITZ.NAS/INTENSO/Video/TV Series/T V S W A T C H I N G/', it won't be added to the library.
2021-03-20 08:45:41.490 T:3814249344 NOTICE: Skin Helper Service --> Skin Helper Service version 1.1.32 started
log-2021-03-20-07.07.10.zip (365.1 KB)
Full Kodi’s log attached.
