So I was debugging my Hyperion.ng and Arduino issues with help of @Lord-Grey in the Hyperion.ng repo and he found out that most likely my issues come from the fact that CoreElec (kernel?) for some reason disables the internal usb hub when device is idle.
GitHub issue: https://github.com/hyperion-project/hyperion.ng/issues/1183#issuecomment-788680457
Mar 01 22:12:48 CoreELEC-M8S kernel: hub 1-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
Relevant part of journalctl:
Mar 01 22:12:48 CoreELEC-M8S kernel: usb 1-1: USB disconnect, device number 2
Mar 01 22:12:48 CoreELEC-M8S kernel: usb 1-1: new full-speed USB device number 4 using xhci-hcd
Mar 01 22:12:48 CoreELEC-M8S kernel: usb 1-1: New USB device found, idVendor=2341, idProduct=0043
Mar 01 22:12:48 CoreELEC-M8S kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
Mar 01 22:12:48 CoreELEC-M8S kernel: usb 1-1: Manufacturer: Arduino (www.arduino.cc)
Mar 01 22:12:48 CoreELEC-M8S kernel: usb 1-1: SerialNumber: 55735323935351B002A0
Mar 01 22:12:48 CoreELEC-M8S kernel: usb 1-1: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Mar 01 22:12:48 CoreELEC-M8S kernel: cdc_acm 1-1:1.0: ttyACM1: USB ACM device
Mar 01 22:12:48 CoreELEC-M8S sh[2891]: 2021-03-01T22:12:48.829 hyperiond LEDDEVICE : <ERROR> Device disabled, device 'adalight' signals error: 'Rs232 SerialPortError: Resource temporarily unavailable'
Mar 01 22:12:48 CoreELEC-M8S hyperiond[2901]: Device disabled, device 'adalight' signals error: 'Rs232 SerialPortError: Resource temporarily unavailable'
Full journalctl log: http://ix.io/2RnY
Is there anything that can be done here? What could cause this - some kind of power saving feature or what? My devices are constantly up and running (I don’t put them to suspend/sleep). The weird thing is that it happens only on one of my devices - Mecool M8S Pro L, the other one KIII Pro is just fine.
Any help would be appreciated.
Thanks!
