Coreelec does not boot in X96 mini
There is a ne version on the nightlies however it does not work for me as a new install or update of previous NE installation. Is it there by error.
New install worked with old dtb.
YO, really? I just got it perfectly in time then! Btw since I understand that S905W2 is a pretty new and hard to work with processor, let me know if you need to do some tests and I might be able to do them.
What do you mean with this? Which image did you use and which DTB?
I just tried the latest nightly with the s905w2 2G dtb but it’s stuck on the x96 Mini logo
Hi
Is there any information how to run CoreElec Matrix 19 or 20 on S905x?
Issue: success start from microsd, resize partition, then reboot, start with CoreElec logo, on boot complete there isn’t any GUI displayed just black screen, may reboot in few minutes. IP allocated at router’s DHCP table, but device not pingable.
My config:
  • X96 S905x 1Gb RAM 8Gb Flash
  • gxl_p212_1g.dtb
Runs Leia perfectly.
What am I doing wrong?
Thank you.
