I installed Coreelec successfully on a x96 mini 6 weeks ago. All is working fine.
I tried to duplicate the same things with a new x96 mini which I bought recently. Same model.
I downloded the recent image onto a USB stick, changed the and tried the toothpick method (like last time)
Does the installation on SD card/USB stick from first box work on this new box?
There are 2 versions of X96 mini boxes, with S905W and S905X processors…
You need to first get it to boot from SD card to be able to install to internal.
But if you do that, we won’t be able to help with many possible issues, as installtointernal is not officially supported.
Please try to avoid double and triple posts, but edit your posts instead.
If the same sd card with different installations (CE/LE) works in one device, but not in the other of the exact same model, there is only one logical conclusion:
Your second device is broken.
