After having succeeded in booting CE on a USB key, the installation was done very well, everything works perfectly. Do you know if I can install it directly on the internal memory in simple boot? Because I have a failure. Is it the fact that it is Google certified? Thanks for your feedback. Cordially
Please ensure ALL requirements have been met.
It tells me that the partition ‘/dev/reserved’ does not exist…
I had to force with -x
