CoreELEC GT COMBO 4k
Hello my brothers
I want to ask you if coreELEC Supports the operation of the device’s internal illumination GT COMBO
If it works, please send my enemies a file DTB
Also, a backup file, noting that my device has a processors 905x3_2g_1gbit
Hello my friends
I own a device GT COMBO 4K With a processor s905x3_1g_1gbit
I want to know if coreELEC It supports the device’s internal tuner operation.
If it supports it, please provide me with the file DTB and backup file .
Thank you
Do you really think someone else beside you has this device? And then you are asking about internal tuner whish really has not much support anyway. And you didn’t rovide any info about this tuner.
There is one thread which is trying to ass support for internal tuners on some devices.
Brother, I want to know if coreELEC the device supports running the internal tuner?
How exactly anyone could know.
Safe bet is “no, it doesn’t support it”. Case closed.
So, according to what you’re saying, satellite channels can’t be operated on coreELEC on a device gt combo 4k?
What they are trying to tell you.
  1. We have no idea what that box is.
  2. When asked you have no clue what hardware that box contains.
  3. Device support is based on physical hardware not brand name on the device.
  4. Tuning support barely works in CE in general.
Given you can’t tell us what actual hardware is in it, soldered on the board, and tuning support barely works on known and supported devices then your chances of it working for you are very very low.
But without knowing what it is there is no way to answer your question.
If I send you a picture and the information you need as a developer, can you activate the tuner on this device coreELEC?
No, device is not supported.
You can add support and make a PR so we include it in CoreELEC.
