hello community, currently I’m having problems with using kodi in coreELEC in ki pro, the boot time is quite long from 5-10 minutes, the current processing is slow and laggy. I am a new member, I hope you can help me
Try unplug all usb then turn on to see if the boot time is reduced?
In my case, when i plug fed usb hub to the box, it took very long time to boot.
this problem is USB, speed low to read and wirte. i am having change usb to TFcard and my problem is done, thanks
