CoreElec NE -> Netflix / Amazon VOD not working
I bought an S905X4 to replace my old S905X.
I could use the same software (CoreElec NG) with a different DTB file.
Everything works like a charm.
If i replace the 512 MB CoreElec NG Boot Partition with CoreElec NE all widewine based addons are not working anymore. Non widewine Stuff like SMB-Playback works fine.
I reinstalled the CoreElec NE via inplace update.
I reinstalled Netflix/Amazon VOD Plugin and updated widewine.
But it’s still not working.
Errormessage is something like: “Theres an error with the plugin”
How can i get logs?
And: Does InputStream Helper Plugin already get aarch64 compatible version?
I’m nearly sure the toublemaker is widewine, but normally i would expect a message like: “No aarch64 widewine found.”
Netflix works with CoreELEC.There’s a problem with Amazon
Where do i get the widewine for CoreElec NE from?
The Netflix plugin automatically downloads widewine.
