On the newest version of CoreELEC (8.95.6) I still have the problem that I’m stuck on the flash screen. It only happens after I shutdown my Minix Neo and after that removing power by turning off a radio socket. Only when I remove the Neo’s power supply and plug it in again, it will boot successfully.
My guess is my Hauppauge WInTV-SoloHD: when I chose a different dvb driver which doesn’t work, the box seems to be booting fine.
Here is a log and error log of a successful boot.
Is there any way to get a log from when the Minix isn’t starting properly?
