CoreElec Updater ?
Hi All,
Is there an Add-on To Update CoreElec like there was for LibreElec - http://devupdater.leopold.me.uk/
No need. CoreELEC will update automatically by default, and you can configure your preferences in CoreELEC settings. Nightly builds are always updated automatically.
@TheCoolest Thanks for that. When I checked for the Available versions it is showing me nothing. Show it not show the same version i am on ?
This works on my C2 as you have stated with the Aeon Solo Skin.
