Hi guys,
as the title says I have a couple of questions/issues with the MINIX NEO A2 Lite used on a Odroid N2.
In the little manual that came with the remote it has for the power button a short and long press action, is this possible with coreelec?
I’ve got the power off working (using the echo “meson-ir * minix_neo” > /storage/.config/rc_maps.cfg
command), but it seems like a hard shutdown. Is this an issue for coreelec/kodi, for example corrupted files?
I tried to set longpress actions via a keymap, but it doesn’t work. Is it straight up not possible or is there something to make it work?
Lastly, has someone recommendations for a keymap. How do you have your remote setup?
Thanks!
