CPM builds
@frodo19 Do you think it would be possible to ask CPM to tag a A6 version of his skin?
I dont know. His decision.
@FubuZ and @frodo19
Thank you both, I have made that change and it works correctly now!
Highly interested in this, thanks for the share. Anyway you can share how it actually looks?
@chuckster or @jamal2367 Do you have any movies with full blu-ray menus that you could test and confirm (or deny) my issues with them?
issue with the original estuary skin too?
Just noticed on “cpm.estuary.A6” skin for SDR broadcasts 1080p “Video Color” value (BT 709) is missing. OK for HDR/DV values are shown.
Will this label be appended to existing labels in Plex or replace what is there?
It will append.
CPM builds here now:
released by him or is this the community’s edition ?
A7 fixed the issues I had with full blu-ray menus.
I suppose it’s because it was rebased on a newer CE build and the experimental buffering code is no longer present? (At least when I look at the debug OSD, the memory counters behind the vq and aq params are gone and they were present with the experimental code).
There are indeed improvements
Teenage.Mutant.Ninja.Turtles.Mutant.Mayhem.2023.iso now OK
Black.Panther.2018._Menu_Test.iso not OK
Good morning everyone. With the A7 version I am experiencing problems that previously occurred less frequently.
The problems I’m talking about appear during the start-up phase of the film, because I often have to stop playback and restart playback several times because an intermittent black screen appears.
Or, when there is no black screen, golden light points appear and move in the video and even in this case I am forced to interrupt and start over.
Has anyone else had the same problems?
Edit:
I apologize if I wrote in the wrong thread. Maybe I should have used the support and help thread.
No, after starting a movie I only have about 1s black screen before video shows; also have this 1s black screen when I jump/seek during playback.
yes, the A7 version also gives me problems when starting the movie, especially with Arctic Zephyr with both version 13 and 14.
Black screen with audio active.
Try the A8.
Any info on changes from A7?
Mostly black frames after seek…
There are improvements to the cpm build bdj menu, and I hope to improve it further. The skin info is also very good
