On another topic, this has diverged from the regular community effort for far too long. At a time when all the help we can get is small considering the amount of work the Team has in its hands this borders insult. So it’s time to cpm to decide if he has time or not to help out. One day, when you wonder how CoreELEC Team decided that it was enough and threw its hands down, you all can visit this forum in archive.org and read this thread.
Anyone having issues with Dolby Vision in the last few days? I think maybe LG C2 WebOS update broke it for me completely… Its all purple for me now.
Edit: Hm okay seems like the last two CPM builds have broken Dolby Vision on LG C2 with the latest WebOS firmware update… Latest CoreELEC 21-ng nightly Generic works.
EDIT:
Problem solved! This is a bit strange, but someone suggested I check if my resolution had changed because someone else was experiencing a similar issue. When I checked, the resolution hadn’t changed.
However, I decided to look at my “whitelist” of resolutions, and I noticed two “new” options at the very top that were checked. I unchecked them, and that fixed the issue for me. The odd thing is, I have no idea how these two new options appeared—checked by default—since I haven’t been in that menu for a long time. I confirmed the issue by checking them again and the problem was there again.
Until now I’m running the CPM build as was recommended on the setup guide.
Now the setup guide doesn’t really mention CPM anymore. Should I just be fine running the nightly builds? Or is there any specific reason for the CPM ones?
I’ve used libreelec then when the split happened coreelec from the start but recently For amB6+ I’m Currently running the cpm build purely Because of DV but there has been no updates since march. Is the new CE 22 capable of DV with the same compatibility/picture quality. I mainly watch Remux 4k on LG g5 so I chase the best picture possible
