hi and sry for my bad english first and foremost.
i have a tanix tx3 max with a s905w 2gbram and16 gbrom.
there is no working android on the device and usb burning tool and usb card maker cant seem to flash the varius images.
all i get is “u boot/get result/disk initial error” be it the original or 3thparty images.
the only boot method i have found that is working with no working android nand/emmc installation is booting from sd with uboot.sd.bin from sdcard and coreelec from usb stick on the same time. but the method is no goob because i have only 2 usb ports.
do anyone know how i can boot uboot.sd.bin and coreelec from sdcard on the same time?
This might help:
Hi, I was in the same situation with no android on emmc.
I used an sd card reader on my PC to burn coreelec image to it using rufus. Then I used Amlogic BootCardMaker to burn u-boot.sd.bin to the same sd card. Now Coreelec boots and works fine from sd .
In your case you should first back up your coreelec installation on USB drive and after you create the new sd card with coreelec and u-boot.sd.bin you can restore. Hope this helps.
thanks for this tip i will test this right this moment
its working first class
now i have not a dead box but a working one ![]()
and this should be go to the FAQ.
i think this could rescue a lot of boxes from the thrash ![]()
From where do you get “u-boot.sd.bin” file?
Hi! this is the one I use
u-boot.bin.sd.bin (784.5 KB)
there is an u-boot.sd.bin in every amlogic usb burning tool image.
i have taken the original firmware for my tanix tx3max burnend it with the “burn card maker”
after i format it with the coreelec image.
afterwards i delete the image and ini file generated from the tool and leave only the uboot file
now in easy steps.
- create a coreelec or other os sdcard
- remove and insert the sd card right back to mount and reread the os partition from the sdcard.
- start burn card maker, select the os partition and your android image that is normaly working on your box.
- make sure that there is no repartition and format selectet.
- burn the image on the card and ignore the error messages. the uboot file is only max 1mb and is the first file that is burned on the card.
- go in your explorer to the sd card and delete 2 of the 3 generatet files (aml_sdc_burn.ini and your android image). MAKE sure that you leave aml_sdc_burn.UBOOT undisturbet or renamed on the sdcard.
- now your sdcard is ready for the not working box to boot without working nand/emmc)
