Cron @reboot
hy
I have a script to backup all the important data to a NAS.
However the @reboot seems not working in crontab -e
I even added a sleep 100 so that the network has enough time to be running
When I schedule a normal cron job like */15 * * * * it works
Can someone help me?
Busybox cron doesn’t know this command.
If you want to run something on boot you can use shell file /storage/.config/autostart.sh.
And put the commands in background
  # your commands
If not Kodi will take longer time to start.
ok thx
in the meantime I made a solution with a service and systemctl
