Hi there, i still got the old bug, it should be alrdy fixed or ?
thats the old thread
here small part from the logg, which shows the same errors:
2019-03-09 23:43:02.874 T:3567252336 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, no pass-through)
2019-03-09 23:43:02.913 T:3618083696 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
2019-03-09 23:43:57.545 T:3812848496 NOTICE: ES: Client from ::ffff:192.168.178.21 timed out
2019-03-09 23:49:18.406 T:3567252336 NOTICE: CVideoPlayerAudio::Process - stream stalled pts:374.048 clock:374.049
2019-03-09 23:49:31.085 T:4066476912 WARNING: ActiveAE - large audio sync error: -12711.572624
2019-03-09 23:49:31.087 T:4066476912 WARNING: ActiveAE - large audio sync error: -12713.888124
2019-03-09 23:49:31.089 T:4066476912 WARNING: ActiveAE - large audio sync error: -12716.587125
2019-03-09 23:49:31.255 T:4066476912 WARNING: ActiveAE - large audio sync error: -13057.396916
2019-03-09 23:49:31.256 T:4066476912 WARNING: ActiveAE - large audio sync error: -12972.397458
2019-03-09 23:49:31.257 T:4066476912 WARNING: ActiveAE - large audio sync error: -12887.396792
2019-03-09 23:49:31.257 T:4066476912 WARNING: ActiveAE - large audio sync error: -12801.397417
thx 4 help
and i really dont know about shell commands
just open putty - login and type the one line ?
Btw fresh install of 9.0.1 on x96 s905x amlogic box
Need help, dont understand the issue
thx
