Hi. As the same Corelec image is used for both the Odroid N2 and N2+, are the N2’s lower cpu clock speeds used as default on an N2+ install? Or are max_freq_a73=‘2208’ & max_freq_a53=‘1908’ settings automatically set on an N2+ install?
I’ve tended to set these manually in boot.ini as I’m unsure. Thanks.
