Default skin, add more player info
Since I added one detailed playerprocessinfo to the cpm build, here,
I made similar, what was possible in normal NE or NG CoreELEC installations.
Some values added, direct playerprocessinfo button builded.
Install from zip, then choose Estuaryce from the skin choose menu.
Note: audio bitrate not show in hd sounds, video bitrate show on mp4 file only.
Feel free to make a PR to CE with such improvements!
Does it show information about FEL in DV movies?
Of course not, since the official CE currently not have those values.
I am interested in the button to call the process player info. Best place for PR is here?
But I am not sure about the player process info extension how it does match for non DV devices as example. So please keep this two parts as separate PR so we can check it in more detail.
missing video stream 8bit or 10bit or 12bit,vs10 mode?fel or mel?
Your MOD3 is the best
IMG_20240926_215211
Not missing. Read once again. This akin for official CoreElec, not for cpm mod. Therefore not have those plus infos.
Okay, understood, thanks
All those values working in non dv devices too. Thats actually call the movie source video codec info.
@Portisch
The button added via pr for 3 commits.
deleted message
Do you have a list of xml or files your have modified for this?I use a estuary mod skin and would like compare to alter and have the same info and button
@Portisch two pr added for the improvement of the playerprocessinfo screen.
Hi, for the button: changes
For the newest playeprocessinfo: changes
Thanks a ton
Didn’t realise I could just check GitHub
Are you able to pull in information used by playerdebug (kodi-send --action "playerdebug")?
Thinking specifically about the current video and audio bitrates, and possibly frame drop/skip info.
I asked, earlier but the devs said that not possible to pull these infos.
Pull requests merged into CE main.
Topic can close.
Thanks.
