Delay start of addons
How do I stop an addon from running after a few seconds with the help of autoexec.py? Thanks
Which addon exactly? And what does stop mean?
Plex addon
The addon is not loaded correctly at startup.
Somehow there should be some way of freezing
sleep i cand set, not working this method
Try Delayed start of addons
I know, it works, but isn’t it something without stopping the addon and start addon?
It is workaround. Because addon itself should behave correctly.
And what exactly is wrong with Plex? I’m sure there are other users without problem using it.
Sometimes the addons doesn’t start, it says to wait 5 seconds and nothing.
Do yuo have enabled wait for network in CE settings addon?
yes, is not work this solution
