Delayed and choppy playback for some videos
I’m running CoreELEC v21.1-Omega on a Minix U22-XJ Max (Amlogic S922X). It palys most of the movie/video just fine but for some videos it takes ages to start; screen goes black and comes back again but eventually start playing. Below is the log from one of those playbacks.
2025-08-03 18:50:45.708 T:3892     info <general>: Skipped 1 duplicate messages..
2025-08-03 18:50:45.708 T:3892     info <general>: VideoPlayer::OpenFile: nfs://10.1.20.62/4kHDR/DemoS/Cymatic Jazz.ts
2025-08-03 18:50:45.709 T:6440     info <general>: Creating InputStream
2025-08-03 18:50:46.012 T:6440     info <general>: Creating Demuxer
2025-08-03 18:50:46.392 T:6440     info <general>: Opening stream: 0 source: 256
2025-08-03 18:50:46.392 T:6440     info <general>: Creating video codec with codec id: 173
2025-08-03 18:50:46.392 T:6440     info <general>: CBitstreamConverter::Open Invalid hvcC
2025-08-03 18:50:46.392 T:6440     info <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2025-08-03 18:50:46.392 T:6440     info <general>: Creating video thread
2025-08-03 18:50:46.393 T:6442     info <general>: running thread: video_thread
2025-08-03 18:50:46.393 T:6440     info <general>: Opening stream: 1 source: 256
2025-08-03 18:50:46.393 T:6440     info <general>: Finding audio codec for: 86018
2025-08-03 18:50:46.393 T:6440     info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2025-08-03 18:50:46.393 T:6440     info <general>: OpenStream: Allowing max Out-Of-Sync Value of 50 ms
2025-08-03 18:50:46.393 T:6440     info <general>: Creating audio thread
2025-08-03 18:50:46.394 T:6443     info <general>: running thread: CVideoPlayerAudio::Process()
2025-08-03 18:50:46.426 T:6442     info <general>: CDVDVideoCodecAmlogic::AddData: Open decoder: fps:60000/1001
2025-08-03 18:50:46.426 T:6442     info <general>: CAMLCodec::OpenDecoder Amlogic device does support DV, DV is enabled by user, display does support DV, DV system is disabled
2025-08-03 18:50:46.435 T:6443     info <general>: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
2025-08-03 18:50:46.458 T:3926     info <general>: CActiveAESink::OpenSink - initialize sink
2025-08-03 18:50:46.659 T:3926     info <general>: CAESinkALSA::Initialize - Configure simple control for "AUGESOUND"
2025-08-03 18:50:46.659 T:3926     info <general>: CAESinkALSA - Use card "hw:0" and set codec format "2 CH PCM"
2025-08-03 18:50:46.660 T:3926     info <general>: CAESinkALSA - Set Spdif to HDMITX to "Spdif"
2025-08-03 18:50:46.660 T:3926     info <general>: CAESinkALSA - Set codec for "Audio spdif_b format"
2025-08-03 18:50:46.660 T:3926     info <general>: CAESinkALSA - Set codec for "Audio spdif format"
2025-08-03 18:50:46.660 T:3926     info <general>: CAESinkALSA::Initialize - Attempting to open device "surround71:CARD=AMLAUGESOUND,DEV=0"
2025-08-03 18:50:46.673 T:3926     info <general>: CAESinkALSA::Initialize - Opened device "surround71:CARD=AMLAUGESOUND,DEV=0"
2025-08-03 18:50:46.674 T:3926     info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2025-08-03 18:50:46.674 T:3926     info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2025-08-03 18:50:47.525 T:6442  warning <general>: CRenderManager::Configure - timeout waiting for configure
2025-08-03 18:50:47.525 T:6442    error <general>: OutputPicture - failed to configure renderer
2025-08-03 18:50:52.454 T:3892     info <general>: Constructing CRendererAML
2025-08-03 18:50:53.011 T:6442  warning <general>: OutputPicture - timeout waiting for buffer
2025-08-03 18:51:03.041 T:6442     info <general>: Skipped 191 duplicate messages..
2025-08-03 18:51:03.041 T:6442  warning <general>: OutputPicture - timeout waiting for buffer
2025-08-03 18:51:07.834 T:6443     info <general>: Skipped 93 duplicate messages..
2025-08-03 18:51:07.834 T:6443     info <general>: CVideoPlayerAudio::Process - stream stalled
2025-08-03 18:51:07.852 T:6442  warning <general>: OutputPicture - timeout waiting for buffer
2025-08-03 18:51:07.891 T:6442    error <general>: CAMLCodec::GetPicture: time elapsed since last frame: 15398ms (11:Resource temporarily unavailable)
2025-08-03 18:51:17.609 T:3892     info <general>: [WHITELIST] Searching the whitelist for: width: 3840, height: 2160, fps: 59.940, 3D: false:(0x4), stereo mode: 0
2025-08-03 18:51:17.611 T:3892     info <general>: Display resolution ADJUST : 3840x2160 @ 59.94 - Full Screen (44) (weight: 0.000)
2025-08-03 18:51:17.612 T:3892     info <general>: VideoPlayer: OnLostDisplay received
2025-08-03 18:51:17.804 T:6442  warning <general>: CRenderManager::AddVideoPicture - timeout waiting for render
2025-08-03 18:51:17.866 T:3892     info <general>: VideoPlayer: OnResetDisplay received
2025-08-03 18:51:17.867 T:3892     info <general>: GLES: Maximum texture width: 8192
2025-08-03 18:51:17.873 T:6443     info <general>: CVideoPlayerAudio: display reset occurred, checking for passthrough
2025-08-03 18:51:17.874 T:6443     info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
Is it like some codec are missing and trying to run in compatiability mode? Can anyone see what might be happening? also, why it says : DV system is disabled?
