DHCP not working with 20.2 install
Hi
I just tried a new install of 20.2 with my Odroid N2+ (19.x was running before), but after flashing CoreELEC-Amlogic-ng.arm-20.2-Nexus-Odroid_N2.img and checking the dtb in root was g12b_s922x_odroid_n2 it boots fine but no LAN ip address was found. CE reports the LAN interface is there, but no IP address. I tried to configure a manual IP but I couldn’t select ‘save’.
Then I plugged in a wifi adapter and the same thing occurs - it sees my SSID but DHCP doesn’t work.
Any ideas?
Your DHCP has issues?
Tx for the reply. Well there weren’t any obvious other problems at the time as I briefly checked it but somehow my pfsense firewall (& DHCP server) died overnight so it was obvs having some kind of issues! Rebuilt now and 20.2 DHCP is working again.
