Hi, I have Odroid N2 and a TV that supports Dolby Vision. However, i’m using a MadVR Envy in between. Can we please have an option to disable Dolby Vision. I get better results with Dolby Vision turned off.
N2 does not support DV at all so it can’t be turned off when it’s not on.
I understand that, however when i played a file that had dolby vision it would just default to HDR as it should. However know with all the dolby vision updates, when i play the file i get funky colours as it is not defaulting back to HDR.
No, not all DV formats like P5 have a no HDR fallback.
To watch them in correct colours you will need a CE DV capable device.
Thanks for the clarification
